3100 Performance
  • Sidewinder
    • May 2006
    • 240
    #46
    Oh ok, so the UIM on the 3500 fits on the LIM of the 3400, and vice versa for the upper for the 3400?
    Do I need get get new heads for those to fit on my 3100 if I keep it?
    Also, someone said that I would need a PCM and a wiring harness from a 98 Lumina/Carlo up in order for me to tune, is that correct?
    Edit: The question should read, "in order for me to tune with a powrtuner"
      • 13533
      #47
      The 97 ecm has more support than the 96 i believe. I don't have any connection with DHP so I don't know what all they support or how well on any of it.
      You should get 3400 heads if you use a 3400 lower. You don't have to but its a better port alignment if you do.
      Yes, 3400 and 3500 are swappable on a 3400 or 3500 lower. 3500 upper and lower together let you port it larger than the other setups.
      • Sidewinder
        • May 2006
        • 240
        #48
        Just out of curiosity, how hard would it be to swap a 60 degree V6 into a J-body (ie. a Cav). I've got a few quotes, and swapping in a manual transmission will cost anywhere from 3-5 grand into my car. I'm thinking I could probably get a manual tranny Cav for cheaper then that, work on a 3400 then swap it in.
        • Tdunk
          • Dec 2006
          • 94
          #49
          Ive heard swaps done both ways 3100's in Cavy's and Cavy Manuals in other cars. It all depends on how much your willing to pay for fab work and tuning.
            3400 swap into a Jbody is easy, lol.
            www.domesticcrew.com
            • Sidewinder
              • May 2006
              • 240
              #51
              I have a feeling that swapping the engine in will be much easier and cheaper than swapping a manual transmission into a car that was never designed for one. I just thought I'd throw that out there, because I think something like a Cav would be much more fun to drive and much easier to get parts for. I like my V6 though
              Also this way I can work on it and still have a car to drive, I'm not sure yet though.
