What can i do with a 3100?
  • Jbrogan
    • Oct 2006
    • 203
    I just bought a 96 beretta with a 3100. What are some good upgrades? I already have a short ram intake, 8.8 wires, and summit coils. I havent put my dynomax on yet though. Also does anyone know if it is better to eliminate the maf sensor, (not ait sensor) mine has both, or buy a jet maf sensor?
    1996 Beretta
    3100 SFI TURBO
    13.1 @ 103 mph best in the 1/4 mile
  • fivepointhustla
    I prefer fast & reliable
    • May 2004
    • 181
    With 185k on the clock either rebuild or buy a shortblock 1st. No need in buying thousands in parts and then boom it blows. But if you want to mod it 1st then do the easy stuff like porting the intake, bigger TB or make it faster by making it lighter. None of these will give you 50hp or even 25, but it will make it quicker and be easy on he motor compared to other mods. What are your mechanical skills? I would do a dual TB intake or a performance cam, but I am not sure if that is over your head
    www.citymotorsupply.com they are the cheapest for a shortblock.
    Clean Feet Pet Clean Up
    Pet Waste Removal Omaha
    We offer dog waste removal and cat waste removal services.
    (402) 320-3824, We service the Omaha, Ne. metropolitan area.
      • 13530
      First order of business is to get a programmer for it so you can tune it for stock, your basic mods, and anything down the road.
      • El_Diablo
        STFUniversity
        • 917
        jet is junk, you dont need a larger MAF sensor than you have stock... theres no reason to delete it either, your car will run a lot better if you keep it
          Yeah leave the MAF and sensors alone. Until you learn more (search!) you can do a full exhaust. 2.25" or 2.5" all the way back mandrel bent with a high flow cat and dynomax sounds good.
          Since yours is a 96, you have ODBII, so you can get a DHP or powertunr and tweak the computer for your modifications to your hearts content.
          Guys with the 94-95 3100's can't edit their computer at all, so consider yourself lucky in that regard!! A car with mods and a computer adjusted to work with them will be faster than a car with the same mods and no computer adjustments. The computer can only adjust so much, so a lot of changes and you don't get the optimal tune unless you can tweak it yourself.
          • Jbrogan
            • Oct 2006
            • 203
            the beretta in my picture is my old one my new one has 56000 miles. also last night i went to the movies and it was fine, when i started it to leave it was ticking. it sounds like lifters. it runs like shit but if i rev it up the ticking stops and it runs great. then if it idles for a while it will start again. any suggestions?
            1996 Beretta
            3100 SFI TURBO
              oil pump slowly dying... But probably lifters or something valvetrain related.
                • 13530
                Could be the piston slap some people have. It will sound like lifters. Also the injectors can make noise too. If the computer is retarding the timing from it though, you will lose performance. You could try to run a little trans fluid in the oil and see if that helps anything. 56k miles on a 96 isn't very many so it may need to loosen up a bit.
                • burnstorm
                  • 5
                  Hey slappy , you mention a programmer is their one / where do I get one for a 3.1 FI it's a 1991 sunbird / cavalier I have both and am just starting my “relationship” with the 60% V6 (all hearts and flowers so far ) !
                    • 13530
                    91 is a breeze. I tune those or if you want to tune it yourself, get a laptop, google "freescan" (should be andywhittaker.com) and get that, go to moates.net and get the burn1 and aldl cable for OBD1. Download tunerpro from moates.net and then get the A1.ecu file from our downloads > tuning files section. Search the forums for computer tuning questions or go to thirdgen.org and check their tech section for the ECM tuning write up. It relates but isn't exactly like our setup.
                    btw, name is sappy and these are 100% engines in 60*V6 form
                    • burnstorm
                      • 5
                      sorry about the “L” should ware my glasses ! Thanks for the info. It will be a big help as I go farther with my new toys, so far I have only opened up the exoust and added a cheap short ram air cleaner,and I already like the look on the face of the first Acura that tried to pass me!
