which valvesprings to choose ?
  • bjornmk1
    • Nov 2006
    • 266
    Hey guys..I want to buy some vavesprings for my alu head
    gen.2 supercharged engine.
    I either gonna buy the edelbrock cam or a 260 cam.
    can someone tell me which springs are best(not to expensive/80$)
    and where to get them ???
    thanx.B
    nothing's impossible-it's just a mindset
    • 13500
    You can either use the springs they recommend for the cams, or find a beehive spring setup that will give you about the same pressure at the seat and at max lift. I think the LS6 springs are the most common recommendation but I am not sure if you need that much spring or not.
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      And LS1 spring would work fine. I would suggest that route. I don't recommend the Crane 99848 springs because I believe they cause a ticking sound at high lift.
        Comp 26915. I just installed a set, they're badass!
