jet or hypertech??
  • Jbrogan
    • Oct 2006
    • 203
    because it is a 3.4 liter so it has more displacement=more horsepower
    1996 Beretta
    3100 SFI TURBO
    T28 60 Trim Turbo at 9psi, Stage 1 turbo cam mms, lifter upgrade springs mms, P&P heads, ls6 Valve Springs, Ported exhaust manifolds, Hyperuetectic pistons SP, 3.29 trani, MSD 8.5 wires, open exhaust, Pulstar plugs, 3400 intake manifolds, ported TB, 36 lb/hr injectors, RCI Fuel cell, Walbro 255 pump, A/C Bypass, and much more.
    13.1 @ 103 mph best in the 1/4 mile
      • 13507
      99 3100 is small port so I wouldn't use that.
      • ignoreance
        • Dec 2006
        • 70
        Can't you just unsolder the chip and then stick a removable style port chip in and program it that way???
        • pontiac3100
          • 226
          there's two of em' that say's flash...and they're pretty small.
          im'a go to the jy and find some 3100 grand prix's and open up the pcm and look for this code that the online tech told me.
          anyway the lg8 (newer 3100) has 175 hp/195 tq.
          while the la1 (3400) has the same hp but 10lb torque.....
          okay seeing the 3400 has 10more tq, the shop that was willing to do it felt more confident with the lg8 than the la1, he said the la1 whould need a couple things swapped...only thing i know whould need to be swapped is the injectors and buy a 94 l82 egr adapter.
          1992 nissan maxima se (190hp/205tQ)
          • gectek
            I Hate Nose Hair
            • Aug 2006
            • 1472
            well IIRC ull need a 99 3400 engine to make sure i get the right signal from the cam sensor, but i might be mistaken. also it isnt just peak TQ and HP that the 3400 has the 3100 beat, its overall power and potential as well.
            • pontiac3100
              • 226
              #21
              but if a 3400 was swapped the only thing whould have to be used from my old engine is my injectors,and buy a l82 egr adapter plate?
              • pw8penguins
                • Apr 2007
                • 6
                #22
                did anyone think about doing a megasquart setup instead. You program it yourself.. Just a shot in the dark..
                • pontiac3100
                  • 226
                  #23
                  whats that?
                  • pw8penguins
                    • Apr 2007
                    • 6
                    #24
                    programable fuel injection. http://www.bgsoflex.com/megasquirt.html so you don't need to worry about if it's obd1 or odb2...
                      JEESH!!! just get a 96 harness from the same model car you have SIMPLE
                      I got an engine harness and modified it to work with my interior one since that changed a little too.
                      BOTTOM LINE
                      you CAN'T tune a 94-95 ECM and you CAN'T unsolder connections to make it tunable.
                      No one has the code or definition file for it anyways.
                      • pontiac3100
                        • 226
                        #26
                        i did'nt know this still exhisted....it does look simple to grab a 96-98 wire harness....how long whould it take to put on etc?
