close to 300 hp wanted
  • eurolumina92
    • Nov 2003
    • 17
    i have a 92 chevy lumina 3.1
    all ready have
    bigger injectors
    bored
    i plan to
    mill the heads
    port and polish intakes and heads
    gasket match
    bigger throtle body
    a fast forward performance chip and underdrive pulley
    cold air in take (all the way to the ground)
    a cam
    headers
    no cat
    40 serias flowmaster muffler
    i don't want a turbo super charger nitro or motor swap
    ithink with this type of work and parts i should be close to 300 hp
    if ther is anythoing i may have left out or if you have help full info please let me know
    thanks eurolumina92
  • Blackrider
    • 131
    Well It might seam like alot of mods but there are people on here with more and arent touching 300HP Its really not that easy. What kind of pistons are you running what type of compression are you wanting to go with? there are a few more things to consider then just the basics.
    2006 G6 GTP MT6
    Vector Motorsports ECU
    Classic Performance 2.5 Inch Exhaust
    v6h.o. Downpipe
    Custom Intake
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      No that will not even be near 300. If you dont want to do a swap the least got with a GEN III top end. Get compression in the 10's at least. Your cam choice will have to be quite agressive to get the power on up high and make the number you want.
      • Anonymous
        And good luck making headers.
        • TurboZ24
          • 299
          300 HP from any 60 degree V6 without a power adder (super, turbo, nitrous) is going to be extremely difficult.
          I do know that they used to get the 2.8's upto around 280-290 Crank HP, but that was a totally decked out race motor, completely non-streetable, 12.5:1+ compression, extreme cam, no idle to speak of, etc.
          Curtis
          91\' Turbo Z24
          http://www.turboz24.com
            • 13531
            go 12:1 compression, crane 272 cam, 3400 top end, custom headers, ported intakes and heads, and larger TB. There is more to it than just those as well...as in properly made headers, matching head work, optimally ported intake manifolds, tuned computer.
            • Blackrider
              • 131
              J body Pref. has a set comming out as i recall. Should be able to mate them up in a lumina
              2006 G6 GTP MT6
              v6h.o. Downpipe
              Custom Intake
              • Anonymous
                I dissagree mine WILL BREAK 300hp after I get my new top end on. But this is a 3.4L....
                  • 13531
                  last I heard they wanted a ton of cash for their headers. I wouldn't plan on a set that fits the J body to fit a W body. Also, most companies just make sets that fit, not optimal sets. If you want close to 300 hp, you need to do all you can to get power out of the engine, which means you have to make an equal length set with the right length primaries. Thats going to be probably 36-48 inches in length. Thats just a guess on my part but its longer than you can easily fit, which means any mass produced set likely wont be made this way.
                  • Anonymous
                    Ed from headersbyed firmly held that 40"+is better. He said he doesn't know why companies even make smaller for he'd rather have manifolds But he said go as long as possible, but fitting them sometimes is mor eimportant. I chose 30' becuz they'd fit, plus totally maximize high end. And he said with the 4 valve/cyl design and the high redline, 30" should be about right, but maybe a little short. Now the guys over at Mymonte.com, they chose an 8" primary, and they aren't equal lengh and they have a larger diameter than the headers on Winston Cup cars.
                      • 13531
                      Yeah, depends on powerband. For 300 hp out of a 3.1 you have to go for high RPM and sacrifice idle quality.
                      • z284pwr
                        • 88
                        I hope you've got lots of money to spend on this motor....because its gonna cost some serious money.....
                        I spent ~$4,500 on just the rebuild for my car, and only had 125 WHP, yes that is with bad tuning and the motor built for a turbo so its obviously sacraficing some cam. Either way, thats 175HP, you've gotta find a lot somewhere.
                        The next question, why? For the amount of money you spent TRYING to get to 300HP you could be making over 500 out of a V8. I just don't see it economically worth it. I guess thats just my opinion though?
                        Brian Edwards
                        '73 Trans-Am
                        '79 Suburban
                        '90 Beretta INDY
                        '90 Turbo Grand Prix
                        '04 TSX
                        '04 TL
                          • 13531
                          3.4 DOHC, 300 is a walk in the park compared to the pushrods.
                          • geoffinbc
                            • 5831
                            Maybe this guys should try and find a wrecked CTS... YEA BABY.. I know I am gonna be keeping my eye out for them along with the 3500. Im sure some goof will wreck his Malibu soon.
                            • 614streets
                              • 344
                              I dont think a 272 cam is gonna push 300 hp n/a. N/A is for suckas.
                              P.S. I wouldnt touch a 112 centerline with N/A with a ten foot stick......
                              1992 Chevrolet S10
                              2.8 v6 tbi 5 speed
