3500 Head ? Help ASAP!
  • Badlands44
    3400 Rockcrawler
    • Aug 2006
    • 28
    I'm ready to start my 3400/3500 hybrid. Filled it up with coolant and its running out a bolt hole in the front of the head. Its about 1 1/4" behind the timing cover and I can't really see the hole. Tried to put a 12mm bolt in it and it seemed right but about 4 threads in it is getting tight. Not sure what to do and I want to get this thing runnin! What goes in that hole?
  • Badlands44
    3400 Rockcrawler
    • Aug 2006
    • 28
    Got it figured out. Its a 12 x 1.5 and I was trying to get a 12 x 1.75 in it. Seems odd because the 3400 heads didn't have holes there and the only other bolt on the engine that thread is the harmonic balancer bolt.
    • Guest
      Doesn't the 3500 use a coolant temp sensor in the end of the head, making that an NPT thread?
      • MY91GT(Z)
        • Sep 2006
        • 387
        yeah its coolant sensor whole this is the same problem rickyline had with his swap and found it out to be the coolant sensor
        • Badlands44
          3400 Rockcrawler
          • Aug 2006
          • 28
          Yup thanks. I didn't even think to search for the answer. Got it running now!
            • 13534
            Awesome Hows it running idle wise? Did you get the cam timed?
            • Badlands44
              3400 Rockcrawler
              • Aug 2006
              • 28
              Its running and idling good right now. Unfortunately I don't have axle shafts yet so I won't be able to drive it for a few days. It sounds great though and the throttle response is crisp. I never did degree the cam, but I moved it a tooth on the chain like you said. The cam timing must be pretty close for as good as it runs and idles. I'll let you know when I get it drivng.
