Roller rockers 3100
  • handshift
    • Apr 2007
    • 22
    Roller rockers 3100
    I notice a few mebers talking about roller rockers . I have the early ones 94 so I now they are not a roller fulcrum . But who sell them out there and what mods . Rocker studs ect would I have to do. To make them work. thanks BB
  • ignoreance
    • Dec 2006
    • 70
    Just buy them from Crane they will send you the studs. but some cars have valve cover issues. Of which I can't tell you if your car is one of those. Oh and I'm not sure you have rollers you may have roller cam but rockers I don't know
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      No valve cover issues witht he 3X00's. But there are lower manifold issues. It will need to be removed for grinding.
        • 13534
        Are you talking about the crane gold race rockers? You have to modify the rocker. I have destroyed a lower intake already trying to clearance and it just isn't happening without modifying the rocker. After I finish the rocker mod to 4 of them, I am going to figure out pricing to do it again and offer modified sets for gen 3 motors. Some manifold modification will need to be done but nothing severe (the same amount to clear the stock gen 3 roller rockers on the older intakes).
        • geoffinbc
          • 5831
          Well we did it on a 3400 lower intake and it worked fine. Maybe the 3100's have issues.
          • rvbilly
            • 46
            Roller Rockers
            Will those factory roller rockers fit 1rst Gen iron heads? What part of the manifold needs to be machined or grinded? Any Pics would be great, are the smallblock Chevy roller rockers the same ? Could they be swapped on our 2.8 iron Heads? thanks Bill..
            • handshift
              • Apr 2007
              • 22
              I check out comp cams they have a set but they are only roller tipp and cheaper but I like the crane . I dont have the roller fulcrum
              I check . But I can see The issue of the manifold It might be easyer to pick up a 3400 intake . And what is 3x00s mean ?
              • geoffinbc
                • 5831
                No the factory roller rockers will not fit iron heads without out some creative machining. The intake manifolds need to be ground on the underside of 2 of the intake ports. This ONLY applies to 3X00 motors. Gen I and II motors need no work at all. Yea Chevy small block rockers are the same. But you MUST get rockers that are used on applications with centerbolt valvecovers. These are narrower than standard wide body rockers.
                • rvbilly
                  • 46
                  Roller Rockers
                  Thanks Geoff for the imfo, Gen 1 & 2 need no machining, is that for the factory or aftermarket rockers, mine are the HO 2.8 iron head 1.725 & 1.425 valves, thanks Bill..
                  • geoffinbc
                    • 5831
                    That is with Crane (or other similar aluminum) rockers. If they fit then anything should fit. Aside from shaft mounts
                      Live life 3.7mi at a time
                      • 4555
                      I thought the SBC rockers have a 3/8's stud and the 60* has 10mm. I belive it is Crane that sells the conversion studs, they bolt into the 10mm hole in the head and are 3/8's above the hex. I have used 3/8's (stamped with roller tip) rockers on my car but the pivot balls and locking nuts didn't work.
                      • geoffinbc
                        • 5831
                        Yea that is correct. ARP also sells the correct fasteners. You can also get ARP fasteners to bolt into the newest heads with 8mm threads.
