4.3l crank specs
  • rickykline
    • Oct 2006
    • 345
    4.3l crank specs
    looking to buy the h beams.. but i want to have the crank specs before doing so... thanks guys
  • Guest
    If you're looking for rod journal diameter, they use the large journal, 2.25"
    • rickykline
      • Oct 2006
      • 345
      i need more info then that..
      if the 3500 rod journal is 2.25inch and the 4.3l rod has a big end size of 2.25 whats the 4.3 crank rod journal diameter? i need to know this stuff before i drop 500 bucks on rods and they end up not working
        • 9189
        http://www.60degreev6.com/showthread...light=4.3+rods
        • Guest
          Well, then you should have included that in the original post.
          If you had I would have answered differently.
          For some reason I'm thinking the 3500 rod journals are larger than the SBC rod journals.
          Take a look in the specs page for the 3500, lik in under "pushrod" IIRC.
          • rickykline
            • Oct 2006
            • 345
            im just trying to make sure that the 3500 bearings and crank will work with the 4.3l h beam eagle rods... now that i have a 700 dollar set of pistons
              • 9189
              As long as the piston pin location is set up to work, or you get a custom rod length... And even then, you'll have to get the 4.3L rods narrowed just like you have to with SBC rods for the older engines.
              • geoffinbc
                Iron Head Enthusiast
                • 5831
                Well 4.3L rods are already narrower than SBC rods. So they might require little to no narroing. I can look in my Chevy Power Manual later
                  • 9189
                  Umm, I tried it since I have all the parts here. They do require narrowing.
                  • rickykline
                    • Oct 2006
                    • 345
                    whats oil clearance with the 3500 bearing in the 4.3l rod on the 3500 crank?
                    • geoffinbc
                      • 5831
                      I thought they might. But it is not as much as a SBC rod.
                      • rickykline
                        • Oct 2006
                        • 345
                        can anyone get me the inside diameter of the stock 3500 rod without the bearing in it and the bolts torqued to specs?
                          • 9189
                          http://60degreev6.com/local_links.ph...id=70&catid=15
                          Page 2... Unless you want real world instead of GM specs, although I'm sure they are going to be within tolerances.
                          • rickykline
                            • Oct 2006
                            • 345
                            im just trying to make sure i maintain tight oil clearances with the 4.3l h beam.. i called eagle rods today and talked to a guy named jimmy he said it wont throw off the balanceability of the rod if you shave the rod big end with from a .930 to a .867 to maintain rod clearance which is good
