looking to buy the h beams.. but i want to have the crank specs before doing so... thanks guys
4.3l crank specs
4.3l crank specs
1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..Tags: None
i need more info then that..
if the 3500 rod journal is 2.25inch and the 4.3l rod has a big end size of 2.25 whats the 4.3 crank rod journal diameter? i need to know this stuff before i drop 500 bucks on rods and they end up not working1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
Well, then you should have included that in the original post.Originally posted by rickykline View Posti need more info then that..
If you had I would have answered differently.
For some reason I'm thinking the 3500 rod journals are larger than the SBC rod journals.
Take a look in the specs page for the 3500, lik in under "pushrod" IIRC.
im just trying to make sure that the 3500 bearings and crank will work with the 4.3l h beam eagle rods... now that i have a 700 dollar set of pistons1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
As long as the piston pin location is set up to work, or you get a custom rod length... And even then, you'll have to get the 4.3L rods narrowed just like you have to with SBC rods for the older engines.-Brad-
Well 4.3L rods are already narrower than SBC rods. So they might require little to no narroing. I can look in my Chevy Power Manual later1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Umm, I tried it since I have all the parts here. They do require narrowing.-Brad-
whats oil clearance with the 3500 bearing in the 4.3l rod on the 3500 crank?1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
I thought they might. But it is not as much as a SBC rod.Originally posted by bszopi View PostUmm, I tried it since I have all the parts here. They do require narrowing.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
can anyone get me the inside diameter of the stock 3500 rod without the bearing in it and the bolts torqued to specs?1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
http://60degreev6.com/local_links.ph...id=70&catid=15
Page 2... Unless you want real world instead of GM specs, although I'm sure they are going to be within tolerances.-Brad-
im just trying to make sure i maintain tight oil clearances with the 4.3l h beam.. i called eagle rods today and talked to a guy named jimmy he said it wont throw off the balanceability of the rod if you shave the rod big end with from a .930 to a .867 to maintain rod clearance which is good1996 beretta w/a 04' 3400 3.5 top end, 42.5lb hr, 180*thermo, t3t4 .63ar 60 trim, LC1 WB, FMIC, greddy rs BOV,TIAL 38mm wastegate,791xv,fidanza,stage III clutch,TG LSD,ffp udp,walbro 255 lph,strut tower brace,22 rear sway,30 front sway,92 5sp tranny,92 subframes,all solid mounts,kyb shocks and struts,eibachs,battery in trunk,tgp map sensor,DHP Powrtuner,euro front and rear and more to come soon...mods sitting in boxes waiting install....zo4 kit,GTU wing,and more..
