3.1 heads w/LS6 Springs NEED Shims?
  • Identity Crisis
    Lost at Birth
    • Jul 2006
    • 295
    I am installing the LS6 Springs on my 3.1L Heads.
    What do I need to buy or install that the heads dont have already?
    ie; small block shims?
    I dont know what this means but "ASS HATS" is funny
    • 13499
    LS1 seats from GM. I orderd 5 sets a while back so that I could put them on the store but they still aren't here. Its going on 3 weeks You will also need seals, but that depends on the year of your heads.
      Ben, how thick are the LS1 shims?
      i used SBC shims on the 2 sets I've spring swapped, no problems yet...
        • 13499
        .045"
          • 13499
          I also have some isky seats that fit and are .060 but they are $60.
          • TurboAlero
            TurboAlero
            • Jun 2006
            • 136
            Hmm , if you dont get the ls shims, hmm you could do a costume, like I did , hmm I took the shim out out of a s10 pickup and cut the valve seal of it because the seal is smaller.
            I did that because I couldnt get the ls shims here at the gm dealer.
            • geldartb
              The Situation
              • May 2004
              • 1994
              where did you order the shims from. i ordered from pace performance and got them pretty quick.
              if it was gm partsdirect they prob got lost somewhere. happened to me a few years ago.
              99 Grand Am GT
              1357 cam 227 233 .050 dur
              515 515 lift 112 lsa
                • 13499
                I bought some off GMPD recently, and then ordered more. They may have run out again if anything.
                • GPXSS
                  • 588
                  When i got mine at a local dealer, they had them in the next day.
                  GMPD is the worst place to buy anything if you need it in a hurry.
                  I modify stuff
                  • Identity Crisis
                    Lost at Birth
                    • Jul 2006
                    • 295
                    The heads are from a 92 3.1L
                    So I will just use stock valve seals.
                    So I will use the shims from a LS1 Engine right? But what vehical has these? I know I know the Fbodys but what years. I am not sure. 99-02 I am thinking. Is anyone willing to provide a GM part number so that I can check my local GM dealer.
                      • 13499
                      I now have 5 sets of shims:P Yes, they take forever but they were cheaper than the dealer here in town.
                      • GPXSS
                        • 588
                        if you tell the dealer you are a parts reseller, they should cut you a discount.
                        When I was buying dealer stuff, I just told them I worked for meineke or quicklube or whatever, and told them the location and left my number to call instead of calling the place
                        I modify stuff
                          • 13499
                          They still can't beat GMPD. I wanted to get 3500 uppers but they were $10 more even after shipping from GMPD.
                          • rickykline
                            • Oct 2006
                            • 345
                            those are the springs i think im going to buy for mine.. revving to 8k would be nice..
                            • Identity Crisis
                              Lost at Birth
                              • Jul 2006
                              • 295
                              NEW "Q"!
                              When installing my roller rockers onto the 3.1L heads do I need to swap the Studs over from the Iron Heads to get the rockers to snug down properly?
