O1 Grand Am tune with rsm set up
  • john_V63400
    Banned
    • Feb 2006
    • 409
    So ive been tuning and i disabled torque management. Messed with the redline and got rid of knock retard. Man it was
    bad. I have the idle set at 800 for the mms stage 1 boost cam. And i cant fiquere how to tune my airfuel ratio. Does anybody know what the numbers mean and do i know higher is less fuel but is that the only basic rule whrn tuning a/f tablez.
  • zofo61
    Banned
    • Oct 2005
    • 436
    MAF Table will adjust the A/F, but you are not running a MAF....therefore you need to put the MAF back in and adjust the MAF Table. Also if you are running a stock 3400 MAP you may have to upgrade to the 3bar so the PCM can see the boost you are developing and make adjustments accordingly.
      • 13522
      2 or 3 bar map but is the ECM going to know what it means?
        I thought he put back in the MAF? The MAF needs to be after the BOV and in front of the throttle body by the way.
