Got my PCM tuned, still poor low end
  • skinrock
    php pimp
    • 64
    First off, I have a 2005 Impala with the 3400 engine. I have done the NAIOA Fender-well Intake, ZZP 2.5" catted downpipe and GMPP dual exhaust.
    I got my PCM tuned by ZZP. They told me it was the same as what you find on their site: http://www.zzperformance.com/grand_p...=182&catid=107
    The biggest thing I noticed is when it shifts from 1-2. The line pressure increase makes the shift nearly instant. Before I would notice a lag, and a slow pull at the start of 2nd gear. Now it's a smooth transition, it shifts at about 50-52 when I go WOT, and as soon as it shifts, it kicks and pulls MUCH better from there to 60 and up.
    Launching still isn't that good, though. 0-20 feels like it's choking, once it gets to about 25, it starts to pull much better from there to 40. I'm pretty happy with the improvement, and the skip shifts definitely wake you up when you go to pass someone.
    My concern is, what can I do for this poor low end? It might even be related to driving skills alone, but I just can't ever seem to get a good take off from stop. I'm assuming it's related to the low idle, 750-1000, and it just feels like it's slow because it takes so long to get it to about 3k where it starts to wake up, so while I'm waiting for that, and slowly moving forward, I feel like I could be going faster.
    Is there a particular part that can help with this? I have the 3500 top end parts, but I think it will come down to having ZZP install it for me, so that's outta the picture for right now. The only other thing I know of is the throttle body.
    ZZP's site says they change some stuff with the torque abuse settings, which is supposed to help with "bog at launch", but I didn't really notice anything.
  • sharkey
    • Jun 2004
    • 2061
    to realy wake it up, get a 3000 stall converter for it. im guessing the impala has a fairly low final drive and a fairly low stall converter. with a 3000 stall conveter you will be into the power band as soon as you put your foot into it. changing your final drive would also get the car moving a bit faster
    • skinrock
      php pimp
      • 64
      Is that something readily available for me? I think I have the 4t60 transmission.
      • skinrock
        php pimp
        • 64
        I found this one: http://shop.rezlo.com/index.php?main...products_id=31
        • skinrock
          php pimp
          • 64
          nvm, it has the 4T65-E, here are the specs:
          1 2 3 4 R
          2.92 1.56 1.00 0.70 2.38
          Final drive on mine is 2.86:1
          • sharkey
            • Jun 2004
            • 2061
            gm did have a 2950 stall converter for the th125. luckily all gm 245mm torque converters are interchangable. i however cant remember what motor used that converter though.
            • skinrock
              php pimp
              • 64
              I guess I should get my facts straight first, does a stall converter literally mean it won't go until it reaches that RPM?
              • 86euro
                • Dec 2006
                • 219
                I thought the newer ones used a different material for the lockup clutch?
                  • 13525
                  You should get a programmer and do it yourself. This will also let you know if you have massive KR or a fueling issue at low RPM. Did ZZP tune the car or sell you a PCM.
                  • skinrock
                    php pimp
                    • 64
                    They tuned mine, I went there. I didn't want to get a programmer for a couple reasons...a little too much, and I didn't really want to mess around with some of those settings. I'm not sure what they all do, and I didn't want to mess anything up. I just wanted a tune that has been safely done before.
                      • 13525
                      Then it should be setup just fine. Your FDR sucks for acceleration but is great for gas milage. That may be the real issue with it then.
                      • sil
                        4T60-E killa
                        • Nov 2004
                        • 723
                        nope, itll feel just like stock
                        except when you floor it WOT from a stop itll spin up to the stall speed
                        ie.. step on brakes real good, press gas pedal, watch tach and see what it says, thats your stall speed
                        any GM TQ wont have that drag racer feel
                        the GM higher stall TQ are a cheaper alternative, they do help launch at a higher rpm(in the better power band)
                        • discostu
                          • Jul 2005
                          • 105
                          Wasn't it the 4 cylinder stall converters that had 2950 stall point?
                          If I remember correctly, the 2.0L OHC Pontiac has one, not sure about the OHV 4 cylinders though...
                          The TH125C has a lockup converter.
                          A 3000 stall converter means that the converter doesn't fully achieve hydraulic lockup until 3000 rpm. Below that rpm and the engine will be allowed to rev up more freely, thus putting it higher into the powerband before transferring full power to the wheels. Much better for acceleration. And with a lockup converter, you will still get great highway mileage.
                          And that 2.86 final drive is killing you. Great for highway trips. Crap for acceleration.
                          • skinrock
                            php pimp
                            • 64
                            I heard the FDR is something that isn't controlled in the transmission itself, is that right? Is it something I can have increased to help acceleration?
                              • 9190
                              The FDR (Final Drive Ratio) is the gear set inside the transmission. In order to change it, you need to change out the gearing inside the tranny.
