Pressed on lobes?
  • torq455
    If I only had money!!!
    • 1615
    Pressed on lobes?
    I've had a few emails to Delta Cams about regrinding my flat tappet cam. 94 Z24 3.1MPFI VinT. They are telling me that that cam has pressed on lobes. thought only the newer roller cams had those. isn't it a bad idea to have pressed lobes on a flat tappet cam? looking for verification.
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
    • 13533
    I am not aware of any flat tappet pressed on lobe cams.
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Agreed. They are cast cores.
        Live life 3.7mi at a time
        • 4555
        Wouldn't a cam from another 60* work? MPFI doesn't have a timing lobe to worry about like the SFI's. This way, you can just order a cam made for a different year/model I'm getting ready to call them again for the cam in my new motor...
        Also, I think they only charge like $30 more for a new grind.
        • rsisbetter
          • Mar 2006
          • 151
          can a pressed on lobe cam be reground?
          cody
          • torq455
            • 1615
            no it can't.
            i'd figure a shop that deals with cams with all the info they need should know if that cam has pressed lobes or not. the only thing i can think of is that they are thinking i have the 3100--even though i told them i had the flat tappet 3.1 vin T.
            Andy
              • 9191
              Originally posted by torq455 View Post
              no it can't.
              Uh, sure it can. There are several people on the site running reground 3x00 cams that are pressed on lobes. I was one of them until I switched to my 3400. And then I send the cam the CNCguy, and I'm pretty sure he is running it in either his current engine or his one that he is building. For awhile, no cam manufacturer would touch a pressed on lobe cam, but in the past 3-4 years, almost all of them have started doing regrinds on them.
              • torq455
                • 1615
                either i was misinformed by Delta Cams or they just don't touch pressed lobed cams.
                Andy
                  • 4555
                  Call again, and order a cam for a 1990 Firebird 3.1. It should bolt right in. My last cam was $100 delivered including lifters (regrind), and $125 if I wanted a new one (with lifters).
                  • geoffinbc
                    • 5831
                    Thats not that great of a deal. You can buy a new cam and lifter kit from GM for $116 and thats Canadian dollars. The grind is the same as a Crane 260 cam. I though Delta cams was really cheep.
                      • 4555
                      Is that delivered? GM Parts Direct charges you shipping on top of the catalog prices. I looked at new 3400 pistons, and they wanted $40 for shipping on top of the $259 for the jugs.
                      • geoffinbc
                        • 5831
                        Dealership man. GM Performance Parts sells in a competitive market so everything is priced accordingly. If you are buying OEM parts then your going to pay a premium unless you know someone.
                          • 4555
                          Thanx for the good info!
                          • torq455
                            • 1615
                            not big enough!!
                            Andy
