3500 Stage2 Upper and 3400 Stage1 Lower
  • Sidewinder
    • May 2006
    • 240
    I have a few questions I was wondering if someone could answer:
    1) what is the difference between the stage 1 3500 upper and the stage 2 is?
    2) Will the stage 2 work on a stage 1 3400 lower manifold?
    3) Will there be a stage 2 3400 lower at some point in the future?
    I was just wondering because I am planning on getting 3400 heads for a top swap, and I wanted to get those upper and lower manifolds to compliment the heads.
    Thanks in advance.
    • 9189
    Are you talking from the 60V6 store?
      1) Stage 1 is gasket matched to the 3400 gasket. Stage 2 is matched to the 3500 gasket which is a lot larger opening.
      2) No, as the opening on the 3400 would be a lot smaller, thus flow would suffer as there would be a lip.
      3) It's possible to open up the 3400 I would imagine. Ask Sappy about it.
        • 13522
        There will be a 3400 stage 2 lower, but not a stage 2 upper. The above is correct on compatibility. I am going to finish up the parts and packages so I can start explaining everything I can, but I gotta do other work at the same time.
        • Sidewinder
          • May 2006
          • 240
          Ok, I was wondering what I could do since things have changed in the store a bit. So does that mean the 3400 stage1 lower would only work with the 3500 stage1 upper?
          What I'm planning on doing next spring:
          - 3400 heads
          - 3400 lower intake
          - 3500 upper intake
          - 62 or 65mm TB
          Other Mods, time and money permitting:
          - MRZ Crank Pulley
          - MRZ Alt Pulley
          - Cam
          - Vavle Springs
          - Headers
          - Full Performance Exhaust
          - 3400 shortblock (once my 3100 shortblock needs replacing)
          Is this a good setup with those intake?
