3100 - Goal: Mild gains over stock N/A
  • tobz
    • Apr 2007
    • 6
    I have a 1996 Olds Cutlass Supreme, 3.1L 4dr sedan. I plan on doing some mild work, and I am fairly new to engine modifications. I don't plan on boosting it, nor do I think I'll magically get 300 HP. I just want something with a little more pickup than stock, for my own satisfaction of a project well-done.
    I was thinking about: Open Air Filter with 2.5" piping, TB from a 3400, custom headers (possibly), high flow cat(s), 2.5" exhaust piping and some Borla mufflers. I want dual exhaust for the nice sound. I haven't looked underneath ol' trusty, but I wonder if true duals are possible?
    That's about it. I would like to know:
    While I am doing this, are there any other not-so-serious mods that I should look into? I don't plan on an engine swap unless mine has severe problems. I'm sure there are a few things I might be overlooking...
    Thanks
    • 13499
    switching to the large port intakes from a 96-99 3400 would be a good upgrade over stock manifolds.
    • sharkey
      • Jun 2004
      • 2061
      i have true dual exaust on my car, and its a pain keeping it from rattling and hitting the floor. if its a driver, id recoemnd sticking with single 2.5" exaust.
      one thing you will want to look into is a way to tune it. doing the mods will get you so far, but unless you can tune you wont see the gains that you should.
      • IanSzgatti
        • Oct 2006
        • 519
        Originally posted by sharkey View Post
        ione thing you will want to look into is a way to tune it. doing the mods will get you so far, but unless you can tune you wont see the gains that you should.
        agreed... one thing that is overlooked too much. I'm new to this engine and site as well, and while I've begun the collecting the parts i'll need, I realize that the most difficult but worthy component is the tuning.
        • tobz
          • Apr 2007
          • 6
          How can I tune my vehicle? Does this step require me to bring it to a shop?
          I was looking at other vehicles, can I get the computer to ODB adapter and get the numbers into my laptop? Then from there make minor changes as needed?
          If there is a good link on tuning that I should see, I will be glad to start reading!
          • tobz
            • Apr 2007
            • 6
            What parts does this require? I may hit up a junkyard to find them. I am guessing this may be a good time to get Phenolic Plenum Spacers if I want to have them?
            Thanks everyone for your help.
            • mbear2489
              Killa Cutlass
              • 60
              the large port intakes would consist of the top two pieces of the motor. the aluminum piece that says "3400" on it, and the attached part below it. as far as tuning goes you can have your PCM (powertrain control module) reprogrammed by a guy named mark. you can check it out and get a hold of him on www.mpracing.org
                DHP powertuner would work with your car since you have a 96. It hooks up to a laptop and you can edit spark, fuel and transmission stuff. You can even swap in a 97 venture van ECM and use that. The reason for the 97 ECM is that it has more memory than 96 did and has more options opened up for tuning.
                For intakes you need the lower and upper and throttle body (it's 56mm vs your 52). Get the metal felpro Lower intake gasket too so that job will never need re-sealing again. You get the gasket for the year of your heads. Make sure you have roller fulcrum rockers when swapping, as if you don't you will need to bolt on some if your head has notches. Most all 96 had them only a few didn't but they should have notches for swapping them over. Non roller rockers will hit the large port intake manifolds. That's why when I did the swap I had to grind my intakes to clear them. (my heads don't have notches to swap over to rollers).
                I don't think there is any other issues for swapping the large ports to a 96.. Unless you are getting the 2000+ ones, those have a few differences like coolant pipe fitting (can be tapped) and EGR (you could swap to new egr and tube).
                For the TB's you can swap the linkages over.
                • mbear2489
                  Killa Cutlass
                  • 60
                  granted, but its like 350 bucks or so. where he can easily get a pretuned PCM that has all that covered for 100
                    Do elaborate on this pretuned PCM you speak of.......
                    • mbear2489
                      Killa Cutlass
                      • 60
                      ok, well i dont know if you are familiar with him, but Mark Petterson? he has his small company called MP Racing. anywho he gets a compatible PCM for you, based upon the service number on it. then he uses the tuning interface he has (not sure what it is) and pretunes it. from my understandings he can do all of the things a DHP tuner can. anywho on www.unitedmalibus.com (the forum part) there are a large handful of people sporting his tuned PCM and can vouch for it.
                      also. i do not have one to personally vouch for it. i dont have a service number on my PCM since its a replacement.... otherwise i would.
                        Oh I see. But mail order tunes are hard to get perfect without having the car there to scan adjust, repeat.
                        • mbear2489
                          Killa Cutlass
                          • 60
                          that i do realize. however, i've looked into the DHP tuner, and its definitely not the easiest thing to maneuver. seeing as it has over one hundred, i think maybe 200 different parameters.... its just a tweak overwhelimg. and also i beleive he offers retunes for free. dont hold me to it im not sure
                            • 9181
                            Mark (who is on this site) uses the DHP PowerTunr to do all of his programming. The way I see it, if you are just looking for a tune and don't plan on doing anything in the future, then a "mail-order" tune should be sufficient. BUT, if you plan on continuing to mod the car, then buying and learning to use your own PowerTunr is the way to go. As you continue to modify the car, you can retune the car for the maximum performance. So it will pay for itself in the end.
                            The other nice thing about having a PowerTunr is the ability to retrieve and clear codes from the PCM. Saves a trip to either a auto part store or the dealership, and could end up saving you money there as well.
                            • mbear2489
                              Killa Cutlass
                              • 60
                              indeed, however i've seen it and it takes a bit to learn it... thats all
