i cant remember, but has anyone confimed if the steel 3500 crank is forged or not?
3500 crank
does any body know if this stroker crank would fit in a gen 2 block and what displacement i would end up with after a .030 overbore ?? and would i need to get diffrent rods or would the onefrom my 3.1 be good ? and what about pistons i was gonna get a set from a camaro can i still get them ?01 olds shilluette 3400/4T65-E stock for now
SO, basically, from what i've gathered is:
1. a 3500 is essentially a punched out 3400, with better flowing top end?
2. The best way to gain cubes is with a 3500 crank in a 3400, (since the 3500 is like a punched out 3400 from the factory?)
Cody
No, the crank has the same throw, but the rod journals were increased from 1.999" to 2.499". People have been discussing offset grinding them to use the smaller journal rods and making a .25" stroker.Originally posted by rsisbetter View PostSO, basically, from what i've gathered is:
Cody
No confirmation yet, but it appears to be billet at the least...Originally posted by 34blazer View Posti cant remember, but has anyone confimed if the steel 3500 crank is forged or not?
I test fit the crank in a RWD 3.4 and it rotates freely. I did not press a piston off a 3500 rod to be 100% sure, but bolted the rod on with the piston sticking out of the block on the oil pan side, and it looks like it would almost make it - of course I could not get a full rotation this way, but gave an idea...Originally posted by montess408 View Postdoes any body know if this stroker crank would fit in a gen 2 block and what displacement i would end up with after a .030 overbore ?? and would i need to get diffrent rods or would the onefrom my 3.1 be good ? and what about pistons i was gonna get a set from a camaro can i still get them ?
oh, and has there been any details on specific model/year that said billet/steel and or forged/steel crank comes in, or is more likely to appear in? last i knew there was no definitive answer.
thanks
cody
'86 Grand National
I took a bunch of pics... here:Originally posted by 34blazer View Postdave can you tell by looking around the throws if its cast or not? if you can can you post some pics?
the crank is just sitting in the block, if you need any pics of different spots just let me know.
You usualy have to hold the crank by the snout isolated with a towel and hit the end of the crank. BUt it seems to be steel. I would be happy just beeing steel.88 Beretta GTU turbo . 90 Black ASC/McLaren TGP, awaiting 4t80. 2003 Grand AM se 3400/4t45 daily grind.
