My 3400 build!
    #121
    Yeah I used to bag stuff. I wouldn't label it cause I could figure out where it went by the other bolts in the bag. But now I don't need to do that anymore. I found some bolts when I cleaned the garage and thought for a minute and was like OH yeah this is from ___ since I changed to the different intakes. LOL
    That silver/chrome looks damn good in bright aqua metallic cars. Would look just as good in mine I bet.
    Well did you fire it up yet?!?!
    • Rhedalert
      Dr. Feelgood
      • 1574
      #122
      Hawwwwwttttt!!!!!!!
      Brian
      3400 SFI V6, 4T60e
      • 19Cutlass94
        • Apr 2005
        • 770
        #123
        IT RUNS! Ill have a vid up soon for you guys.
        3400/Getrag 284 5spd
        350/NV3500 5spd
        2014 Chevrolet Malibu LS
        • zofo61
          Banned
          • Oct 2005
          • 436
          #124
          Congrats.....!!!!!.......Nice Job.........I want to hear it go baby go
          • 19Cutlass94
            • Apr 2005
            • 770
            #125
            Heres a short vid of it running!
            I think this ECM is handling this cam/motor very well. It idles GREAT, doesnt search for an idle, and RPM range seems VERY smooth ( up to 2500RPM, havent gone further )
            Ill still need to drive it for a little bit before I can datalog it, but so far so good
            On a side note, Id like to THANK everyone here that helped me with this project! Your help was HUGE in getting this running like it is now.
            350/NV3500 5spd
              #126
              Are you going to use my definition files to data log it? You're still OBD1.5 right?
              • 19Cutlass94
                • Apr 2005
                • 770
                #127
                yeah Im still 1.5. I might use them. Well have to see when the time comes. Im going to drive it for a couple weeks, nice and easy.
                350/NV3500 5spd
                  #128
                  Cool. How else would you datalog it? TunerproRT is the only thing out there for 1.5 other than ScannerPro which is related.
                  • 19Cutlass94
                    • Apr 2005
                    • 770
                    #129
                    The OTC tool I have here will give me a print out of every function. Ill be able to read the whole system. Ive got a print out from the 3100, I should probably post that to see what you think.
                    350/NV3500 5spd
                      #130
                      Oh yeah that's right. Sure post it up.
                      I like ScannerPro cause you can play back and view everything in real time. Even use analog gauges. TunerPro is good cause you can reset codes with it, but for some reason it can't record the datastream without corrupting it on obd1.5, so play back doesn't work.
                      • 19Cutlass94
                        • Apr 2005
                        • 770
                        #131
                        yeah. I have only 1 problem with it right now. The Low Oil Level light keeps coming on. Any ideas? I thought the ECM didnt look at that, Like the way I understood it was the circuit was open until the oil level got below a spot on the sensor and the sensor closed the circuit, curning the light on...
                        350/NV3500 5spd
                          #132
                          Should of swapped pans... LOL j/k. Either you disconnect the sensor and let it hang, or ground it out and it will shut up. I forget which.
                          • 19Cutlass94
                            • Apr 2005
                            • 770
                            #133
                            haha. well right now the sensor is hanging, so Im guessing I need to ground it out?! Although with it hanging there, the oil light doesnt come on 100% of the time. its kind of random when it comes on.
                            350/NV3500 5spd
                              #134
                              Oh well maybe the sensor is being moved around then? Tape it up so it can't move downwards! Or try disconnecting it and see what happens then.
                              • geldartb
                                The Situation
                                • May 2004
                                • 1994
                                #135
                                disconnect the sensor it wont set the light. i did that when i initially swapped in the 05 3400 without the sensor in the pan. drove around for a week with it partially dangling and no light for me.
                                all i did was cut the plug off and wirenut the the wire and tape it all up and stash it up on the subframe.
                                99 Grand Am GT
                                1357 cam 227 233 .050 dur
                                515 515 lift 112 lsa
