3.1 MPFI modding
  • Stonedified
    • Oct 2007
    • 30
    3.1 MPFI modding
    I've been thinking about replacing my cam, fuel injectors, and fuel pump on my 1993 Cutlass 3.1 MPFI, with higher performance versions...
    If I replaced any or all of these, what other changes would I have to make?
    And does anyone make an actual ECM programming module for my car?
    1993 Cutlass Supreme SL Coupe - 3.1 MPFI
    Performance:
    -Cone Air Filter. that's it.
    • 13533
    If you want to tune, you will need a laptop, aldl cable (moates.net), software (tunerpro, moates.net as well), and a chip burner (moates.net). We have the files here you need.
    • Stonedified
      • Oct 2007
      • 30
      hmm...is the laptop 100% necessary? and how much would the rest cost me, if you know off the top of your head roughly?
      Performance:
        • 13533
        Hard to drive around with a desktop hooked up for logging. Under 200. You need a chip adapter and a chip, which I think its 35 bucks. Cable is 80. Burner...i forget.
        • Stonedified
          • Oct 2007
          • 30
          true true...and thanks a bunch.
          also, if I were to just replace the cam and pushrods...would my car run correctly without changing the tune, let alone perform better?
          Performance:
            • 13533
            You can do a cam without a tune, it just won't be as good as it could be. The comp 260 or crane 260 would be fine. Pushrods only help.
            • 3.1cutlass
              • Feb 2007
              • 101
              I have the comp260 cam just not installed yet. FYI you will have to lower the motor some to install a cam. If you want to play with the computer without buying all that stuff just buy a chip from the store on this site.
              • Stonedified
                • Oct 2007
                • 30
                awesome, thanks and btw what do you mean by lower the motor?
                Performance:
                • 3.1cutlass
                  • Feb 2007
                  • 101
                  Unbolt the subframe and put it on jackstands and lift the car away from the motor
