I searched a couple of sites and cannot find a how-to on swapping throttle bodies. Will I need to remove the UIM? If so, will I need a New gasket?
Help Installing throttle body 97 3100
Last edited by Z3R0; 10-30-2007, 12:23 PM.Originally posted by wozxx...{is 92 mph in a school zone illegal?}I was going relatively fast thru a school zone and was caught. However, I managed to zip into a neighborhood and evade the cop. Could I get additional tickets by trying to run?Tags: None
Do you just need to swap the TB or the TB plate? If its just the TB, Theres only 4 bolts... Two that hold it onto the UIM and two on top for the linkage bracket. Youll also need to take off the coolant lines that run to the TB.sigpic
3400/Getrag 284 5spd
350/NV3500 5spd
2014 Chevrolet Malibu LS
Both, but I read the instructions for how to take apart the linkage so I'm good with that...thanks for the response...I appreciate itOriginally posted by wozxx...{is 92 mph in a school zone illegal?}I was going relatively fast thru a school zone and was caught. However, I managed to zip into a neighborhood and evade the cop. Could I get additional tickets by trying to run?
Swapping stock for RSM's version of 62mm.Originally posted by wozxx...{is 92 mph in a school zone illegal?}I was going relatively fast thru a school zone and was caught. However, I managed to zip into a neighborhood and evade the cop. Could I get additional tickets by trying to run?
Wouldnt that cause a problem as the Tb opening is much bigger than the plenum opening?
BTW since were on TB's, Ben do you need 3400 linkages? Ive got one at home that Im not using.sigpic
350/NV3500 5spd
You will need to port the manifold to 62mm as well. If its the stock 97, you have small port manifolds. Better off swapping to large port manifolds and porting that out to the larger diameter.Ben
Hmm maybe payday I'll buy on of yours....the Stage 1 3100 Lower Intake is already ported and costs a flat $200 before shipping right?Originally posted by wozxx...{is 92 mph in a school zone illegal?}I was going relatively fast thru a school zone and was caught. However, I managed to zip into a neighborhood and evade the cop. Could I get additional tickets by trying to run?
Ill send one out your way this week.sigpic
350/NV3500 5spd
Correct, 200 for a ported lower intake plus shipping to your door.Ben
