1280 grind cam problems, install strait up?
  • merlot566jka
    • Nov 2006
    • 570
    ok things arent looking right here... the #1 is at tdc and the intake and exhaust valves arent on thier base circle....am i supposed to degree this thing or does it install straight up?
    #4 is close to tdc and has both its lobes on the base circles....as if the firing order is 456123... whats the deal?
    the marks are ligned up on the crank and cam....this isnt my first cam and def not my first 60*v6 cam install....
    or maybe its just lack of sleep
    2012 Chevy Sonic Turbo 6spd
  • JMo60
    • Oct 2005
    • 300
    you sure you dont have the engine 180 off?
    94 Grand Prix
    • merlot566jka
      • Nov 2006
      • 570
      how can that be? the timing mark on the crank points towards the cam and the cams timing mark toward the crank.... i dont see how it can be 180 off if the alignment marks are in place....
      you can make a dist 180 out, but not here
      • zofo61
        Banned
        • Oct 2005
        • 436
        I just looked at the bottom end of my 3500 and the crank dimple is at 12 o clock and my cam line is at 12 o clock making #1 and # 4 pistons at the top of their stroke.
        • merlot566jka
          • Nov 2006
          • 570
          yes, thats how all of the 60* v6 engines are.
          my problem is that when #1 is at tdc the lobes on the cam are not on thier base circle for the #1 piston. the problem is not with the crank, or the timing....
          • JMo60
            • Oct 2005
            • 300
            a cam turns half speed of the crank, so you can be 180 off.. you are not on the compression stroke like you are looking for. im not 100% because im not lookin at it. but yeah it can be off
            94 Grand Prix
            • JMo60
              • Oct 2005
              • 300
              sorry i didnt read your previous post.. I dont know what it could be then
              94 Grand Prix
              • torq455
                If I only had money!!!
                • 1615
                if #1 is at TDC and both valves are open slightly, that the TDC of the exhaust/intake stroke. you can have the timing marks off 180. rotate the cranke one more turn without the cam and see what happens.
                Andy
                fastest 1/8: 10.19@ 67.17
                fastest 1/4: 16.16@ 82.70
                  • 13534
                  The stock cam doesn't have either valve on its seat at TDC with the cam timed properly. Valve overlap from the intake opening and exhaust closing will be during TDC. Spring the crank around 360 and the cam is 180, putting both valves on the seat for the combustion/exhaust event.
                  • merlot566jka
                    • Nov 2006
                    • 570
                    so its right the way it is...maybe i should be sleeping
