Test: 3500 crank in 3.4
    Live life 3.7mi at a time
    • 4555
    i thought it was forged pieces make the ring and cast parts make a clunk
    That's what they said (post 13)
    • 34blazer
      • Sep 2007
      • 341
      so did you find out if its forged or not? id really like to know so i can snag a couple
      '86 Grand National
        • 4555
        Just got back from a week-long trip. The 3500 cranks are at the shop, as soon as I get over there (probably after holidays) I'll compare a spare 3.4 crank to one.
          • 13524
          They ring like a bell.
          • zofo61
            Banned
            • Oct 2005
            • 436
            ding ding goodness!
            • torq455
              If I only had money!!!
              • Dec 2003
              • 1615
              #21
              i thought it was a bad idea to intensionally impose a harmonic on the crank. aren't those bad? like the argument of to dampen or not. i'd never consider tapping any crank with a hammer.
              Andy
              fastest 1/8: 10.19@ 67.17
              fastest 1/4: 16.16@ 82.70
              • latemodelnewbee
                • Jun 2007
                • 227
                #22
                If you tap your crank with a hammer and it rings it doesn't mean that its forged, it only tells that your crank is not cracked cast iron cranks will still ring. The hammer test is a old machine shop trick to make sure that crank is still good before the customer leaves and they do any work to it. Now the ringing will be different from cast iron, nodular iron, cast steel, forged steel, or billet steel but they all ring, not thud or clunk
                68 El camino 454 speed muncie 3.90 posi 12 bolt,
                80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
                60 Impala 2 door hardtop L79-327 T56 4.11 posi.
                83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
                91 Z34 now has a hm284. and belly pan in the works
                • 34blazer
                  • Sep 2007
                  • 341
                  #23
                  every cast crank ive tested like that had a clunk. when i bought a forged crank it rang like a bell. so if you want to know if a crank is cast or forged, how would you test to make sure. because something doesnt add up
                  '86 Grand National
                  • RedBird
                    Aka Mr. 5th Motor
                    • Sep 2006
                    • 426
                    #24
                    Well i just went out to my garage and tapped the 3400 crank i have sitting on the shelf. It rings. Just FYI for all you guys Does it make a difference what kinda of hammer you use? cause there's hardened vs non-hardened and stuff.... i used a ball-peen
                    Cammed 3400 --> 224whp 210wtq
                    Cammed 3500 --> ???
                    1 of 5 3500 J-Bodies
                      • 9189
                      #25
                        • 4555
                        #26
                        Well, today a 189 crank rang like a bell and the 3500 cenak rang as well, but not as long.
                        I think the ringing is irrelevent and not consistant.
                        Being a machinist, I can tell by looking that the 3500 *7489* crank is machined on most surfaces and the 981 (3.307 stroke, 1.999" rod journal from a 3.4) crank is definately fully cast and only machined for clearances.
                        • 34blazer
                          • Sep 2007
                          • 341
                          #27
                          so what is the 7489 crank, forged or not?
                          '86 Grand National
                          • latemodelnewbee
                            • Jun 2007
                            • 227
                            #28
                            you can tell by the flashing, if its thin and jagged its cast, if it's wide and flat its forged
                            • 34blazer
                              • Sep 2007
                              • 341
                              #29
                              Originally posted by latemodelnewbee View Post
                              you can tell by the flashing, if its thin and jagged its cast if wide and flat its forged
                              that would help if i had a 3500 crank sitting in front of me lol
                              '86 Grand National
                                • 13524
                                #30
                                Its narrow on the 3400, wide on the 3500.
