Not Crane, but...
    Live life 3.7mi at a time
    • 4555
    Not Crane, but...
    Couldn't resist a good deal. Got these for $100. Now I have to spend more money for the adapting studs, but gain adjustability and full roller rocker arms
    They are from Summit (1.6 ratio).
    Sets me back a little (as far as time) because of clearance, but will be worth it in the end.
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Not bad. Includes 4 spares LOL.
      • 4555
      Actually 3. The reason they were sold is the guy's pushrod made a dent in one
        • 13525
        those aren't too wide?
          • 4555
          They look like Crane copies to me, but can take some measurements. What's the measurements on the Crane's?
            • 13525
            1.193" wide.
            • geldartb
              The Situation
              • May 2004
              • 1994
              isnt there anything that isnt the stock ratio. yeah its nice that they are full roller but i want something other than stock ratio.
              99 Grand Am GT
              1357 cam 227 233 .050 dur
              515 515 lift 112 lsa
              • geoffinbc
                • 5831
                Harland sharp sells 1.65 ratio.
                  • 4555
                  IIRC Summit also has a set of 1.8's, but $800 is a little out of my price range.
                  You don't need a ratio that high if you get the extra lift from the cam valve lift is valve lift - no matter how you get there.
                    • 13525
                    There is more to it than that though. A higher ratio rocker doesn't need the pushrod and lifter to travel as far. There are advantages to high and lower ratios.
                      • 4555
                      I agree, but when talking about spending 8x the money for minimal gains is not as crucial in a street driven car. Even still, you have to remeber that a higer ratio rocker will stress the cam more.
                      The rocker works like a see saw. If one person is real close to the fulcrum of the lever, they need to be much heavier than a person sitting at the far end of the opposite side.
                      Imagine if one of us even went as far as using some hydraulic-actuated valves in a 660? The Indy cars can't even have a cam anymore due to the high revolutions and huge ratios.
                        • 13525
                        I like the ball shaped "valves" I saw once. Had cutouts for the open events and just spun around.
                          • 4555
                          ^^^ Now that's thinking.
                          1.193" wide.
                          The body, or the ends of the fulcrum?
                            • 13525
                            fulcrum/body, same thing on these cranes cause they don't stick out at all.
                              • 4555
                              The Summit fulcrums are wider than the bodies.
                              EDIT: Now I regret not taking measurements. Just kind of set one in place to eye them.
