head swap info
  • zs&tas
    • Jan 2008
    • 4
    head swap info
    hey, i want to ditch my 88 birds 2.8 heads and was thinking early 3.4 heads would open it all up alittle, will they bolt straight up and to the L/UIM so would look stock????????????????????
    any info would be great thanks - p.s. i know most of you will just say swap engines out....... not yet thanks
    keep up the good work eh
    • 13534
    No, you can't use your 2.8 manifolds.
    • zs&tas
      • Jan 2008
      • 4
      why? whats the difference??? thanks
        • 9191
        Are your 2.8 heads alum or iron? And when you say early 3.4 heads, are you talking iron (3.4L from the Camaro) or aluminum (3400)? Reason I'm asking is because iron heads and aluminum heads have different port configurations, therefore the manifolds are not compatible between the 2. But if you are talking iron to iron, its a waste becasue they are the exact same head.
        • 3100 MPFI
          • 1522
          oops. Wrong thread.
          Taylor
          1998 Lincoln Mark VIII
          • zs&tas
            • Jan 2008
            • 4
            not sure, whatever came on a 88 firebird?? thanks for the info, i take it when people say 3400/3100/3500 there talking ally then??
            i would have though the early 3.4 firebird/camaro heads would flow beter than the 2.8's about 1994 ish ?
            but if there the same ill just polish mine up.........
              • 9191
              If its a Firebird, then they are iron heads (all RWD engines got iron heads). And yes, the heads are exactly the same between the 2.8 and 3.4 engines. There has only been 1 change in the iron heads, and it was back in like 85 or so. All heads since then, and up until 95 (when iron head 60V6s ended) are exactly the same.
              • zs&tas
                • Jan 2008
                • 4
                cool thanks bszopi
                  • 13534
                  Ah, I was thinking sunbird:P
                  • Mr_Efficiency
                    • Jan 2008
                    • 197
                    ^^^ so was I, lol
                    Mr_Efficiency
                    90 Grand prix - Lawn ornament
                    Black, 3.1, 5 speed
                    Future holds: Striped and then scrap yard
                    97 Cavalier - Stock car
                    Red/Black, 2.2 OHV, 5 speed, fully tubed bumper to bumper, 6 point cage with halo, fuel cell, race seat, 5 pt harness.... a race car
                    Future holds: Just more trophies
                    New project on the way: 88 S10 reg cab, short box, 5 speed.
                    Future holds: Built 2.8 hybrid, Stealthy flat black, a drop until i have no more ugly wheel gap
