3500 build plans
  • rickykline
    • Oct 2006
    • 345
    3500 build plans
    looking into building my bullet proof 3500 now that i have lost another rod in the 3400 i have put together a list of stuff that i will we doing. im trying to find a 3500 locally with the 7484 crank.
    the block will get stripped down and bored .020 over for the custom made wisecos i ordered some time back. im going to mate the piston to a set of 4.3l v6 h beam rods and have the big ends of the rods shaved down and the rotating assembly balanced. im looking at getting bens stage 3 turbo cam and the comp cams springs from the store along with the longer pushrods. i was wondering if ill need the bronze gear with that cam? i am going to use a stock set of 3500 heads mated to my 3500 lower and a ported 3400 upper.my only real issue seems to be getting a external crank trigger seeing as the store here on the site is out of stock.
    is there any complications with bolting my 3400 front cover to the 3500 block? so i can keep the mounting of the tensioner alternator and powersteering pump the same? what about the bracket for the axle shaft on the rear of the block will it line up? and what about the a/c compressor will it bolt to the 3500 block? i never could line up the bottom bolt on my 05 3400 and i didnt have any issues with that.
    the car is a 96 beretta with the following mods..
    05 3400 w/3.5l top end, 42.5lb hr injectors, t3/t4 GARRETT .63ar 60 trim, front mount intercooler, greddy rs BOV, tial 38mm wastegate, 3" exhaust, high flow cat, 180* hypertech thermostat, fidanza flywheel, TG LSD, spec stage III clutch, ffp udp, walbro 255 lph, ffp dogbone, Ingall Camber Bolts, GM strut tower brace, z51 rear sway, fe3 front sway, new 92 5sp tranny, 92 subframes, poly control arm bushings, poly sway bar bracket bushings, poly endlinks, poly z51 bushings, carcustoms poly mount, kyb shocks and struts, eibach springs, battery relocated to trunk, TGP 2 bar map sensor, DHP Powrtuner, euro headlamps with 6k HIDS, euro tails, viper 791xv, Bfg drag radials, Goodridge G stop SS lines
    the 3400 and 3500 timing covers are nearly identical, they'll swap just fine.
    • rickykline
      • Oct 2006
      • 345
      will i need any shims for the valve springs or can you think of anything i missed.. do i have to run a certian valve seal with the comp springs? i dont like suprises when it comes to dipping into the savings account lol..
      • rickykline
        • Oct 2006
        • 345
        stage 3 turbo cam $310.00
        comp valve springs $175.00
        crank trigger $130.00
        custom pushrods $135.00
        4.3l h beam rods best price ive found is $410 shipped
        someone has to have a crank trigger they dont need so i can get this bad bitch going..lol
          • 13534
          You don't need the bronze gear for the regrind. TCE is working on the triggers but I am not sure how long until they are finished.
            A/C will have same issue as the 05 3400 did but will bolt up.
            • rickykline
              • Oct 2006
              • 345
              i hope they will have some for us in the next week or two.. im ready to get this show on the road...i hate driving my pathfinder..lol
              • SE'sarecool2
                Gearhead for life
                • Jan 2006
                • 76
                With that turbo & stage 3 cam I would seriously consider porting the heads if I were you.
                -RUSH
                  If you run the 26986 springs you can use the stock valve seats and seals, i almost wish i had gone that route..
                  • johnnymossville
                    • Jul 2007
                    • 255
                    Yep, thats the way I set up my 3500 heads and everything went together like it came from the GM factory.
                    • Joseph Upson
                      Delta Cams recomended Smith Brothers to me for the push rods and they made me a nice hardened set for under $100 for the 3900 regrind.
                      • loner666
                        • Oct 2006
                        • 435
                        Ricky, if i was you id get atleast a bigger exhaust housing. I have the same turbo as you (the one you showed me sometime back) and it surges at low RPM, boost faster then a pissed off ape and im not sure if its maxing out or not as i have no gone WOT with it yet..i only have mild port and polish 3500 top with i think the stage 1 turbo cam from here
                        dont get me wrong its awsome as hell but im thinking of getting a .82AR exhaust to replace the .63AR i have now to combat the surging and get it to spool alittle later into the powerband
                        Best 1/4mile ET - 12.9
                        Best 1/4mile MPH - 111
                        1997 Ford Ranger Splash
                        Daily Driver
                          • 13534
                          How do you get pushrods below jobber? Hook me up.
                          The stage 1 and 2 cam are designed for the best low end. You have the stage 2 cam (.533 lift).
                          • loner666
                            • Oct 2006
                            • 435
                            Eh i was close..i couldnt remember and i didnt wanna look it up..its a fun cam tho..got me a 14.8 NA so im not complaining..should be seeing the track again in a few weeks for some boost runs on it
                            Daily Driver
                            • Joseph Upson
                              Assuming you are talking to me, there was no hook-up, I told them Delta Cams referred me and the price was about $100 shipped. I was surprised also since they were hardened but was told they run a hardening process weekly so the time that I ordered them came into play as it was just before they were scheduled for a routine process. Crane Cams wanted more I don't remember how much more but it was enough for me disregard eventhough they are within 170 miles of my home. I didn't mention it here before because I didn't want to affect sales in the store.
