Dont use Bronze gear with Milzy cam.
    This is why... give it another 10k and I would have had no oil pressure... This is on my 15k mile Daily driven hybrid with a milzy stage one and LS6 springs.
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Ouch. I wonder if the composite ones last longer.
    • silvergtjrad
      uber slow grand am
      • Feb 2007
      • 302
      Ouch, I'll take that advice.
      • 19Cutlass94
        • Apr 2005
        • 770
        yeah Im using the stocker in mine.
        3400/Getrag 284 5spd
        350/NV3500 5spd
        2014 Chevrolet Malibu LS
          I'm going back to the stock one with the new cam Ben is grinding for me.
          • blackbombshell95
            Kaiō-ken X 10
            • Jun 2004
            • 1386
            What cam are you going with? Stage 3?
            02 GTP - 90* > Failboat
            www.blackbombshell95.com
            • Rhedalert
              Dr. Feelgood
              • 1574
              was there a reason not to use stock? Too hard for the billet cams?
              Brian
              3400 SFI V6, 4T60e
              • El_Diablo
                STFUniversity
                • 917
                not hard enough i thought? ehh... ive been down the no oil pressure route before, thats how i seized the first engine, lol
                  Milzy's site just said to use the bronze gear with his... not sure why, so I tried it... BAD IDEA.
                  And no I'm not going with a stage 3 cam I'm going with a custom one.
                  216/240 278/289 .517/.568 113 ICL 114
                    • 13520
                    No, The company he got his cams from recommended a bronze gear or a mellonized gear. I wasn't aware he actually said to use it, as I was the one that originally posted that the stock oil pump drive gear may be a bad idea for the billet cams. The point of bronze is to wear, so you don't wear the gear on the cam. Its doing its job. As for how long it is lasting, I don't know how long they are supposed to last. Billet steel is going to wear it faster than the regrinds I sell, but you dont need bronze on regrinds.
                    The DOHC oil pump drive gear looks different than the gen 3 pushrod gear. It must be mellonized given no one has had one fail yet. If it wasn't, all the billet cams would have no gear left on them.
                      I guess this is true, but thats a lot of wear for 15k miles... its not like I had a high volume or high pressure oil pump either... thats all still stock.
                      Oh well I'm going stock with your re-grind so I should be all set.
                      I'll post pics when i get home but do you think I should do my cam bearings too??
                      • JohnnyReb
                        • Nov 2007
                        • 49
                        Gotta use bronze on a billet cam. Even factory billet cams use the bronze gear. A billet cam will devour a regular dist gear. I tried a poly gear on a L98 and even though it looks and feels like a joke they are worth the money. What does the finish look like on the cam gear. Is it rough? I bought a Lunati cam once that ate 2 bronze gears in less than 30K then finally quit and still running the 3rd gear about 80k later. In comparison to a GM cam you could visually see the diffrence in gear finish. Ligenfelter offered billet cams with a ordinary gear pressed on to solve the dist gear problems but I doubt anyone offers these for the v6.
                          The cam looks unscathed... But since I'm going with a regrind this time I can use the stock gear, so I should be all set.
                          But yeah no one makes a press on gear for the billet cams, but since there are so many solid core regrinds avilable now there is no reason to use a billet one... at least I don't think there is.
                          • 666Racing
                            • Feb 2010
                            • 18
                            Bronze/Polymer/Mellonized distributer gear
                            ...looking for a Bronze/Polymer/Mellonized distributer gear for an old Crane 260 degree @ .050 .625 lift billet roller cam...is the oil pump drive stub gear the same as a distributer gear? Are any factory gears mellonized?
                              • 13520
                              Yes they are the same and the gen 3 are mellonized. I also have 1 bronze gear here that someone wanted and never claimed.
