3400 top end vs 3500 top end
    Live life 3.7mi at a time
    • 4555
    Piggyback Megasquirt for simplicity. The ICM is looking for the same signal as the HEI would recieve on a Gen1 60* (with a distributor). Then use the MS to control your fuel and leave yhe stock ECM hooked up - and just splice in a "t" for the sensors to go to both computers. The only bad thing is MS can't be mounted underhood like your stock ECM is, but DIYAutotune.com sells a nice pre-made harness with labels running the entire length of them to avoid confusion (18" and 12' lengths last I looked).
    If you learn tuning first it will be easier to do the mods later. I did things the other way around and have learned my lesson, lol. Blew my 3.1 twice trying to get the proper fuel under boost.
    • niik000
      • Jan 2008
      • 24
      im assumeing your the same guy on camarov6 firebird v6.com, thanks for the info. but you lost me on this part: "The ICM is looking for the same signal as the HEI would recieve on a Gen1 60* (with a distributor)" dumb person tearms please?
        Some sensors you can't share with 2 ECMs. But that's no biggie. The MS comes with it's own MAP anyway. Yeah you'd piggy back so you'd still have your gauges/etc.
        • niik000
          • Jan 2008
          • 24
          thanks marcellis wallis/duke of new york. but here comes a relly dumb question, so i pull my motor, pull the top end off, pull the cam off, pull some other stuff off to replace gaskits and stuff, put the new cam in, put the new top end back on, piggy back the MS, but thenwhat? how doi tune it? how do i know what A/F ratios to use and stuff?
            • 4555
            Go to MegaManual.com and read the section on wiring. Keep in mind the ICM can be hooked up just like a distributor.
            Yes I post at fbv6/cv6 and use the same screen name
            • niik000
              • Jan 2008
              • 24
              #21
              if i got mega squirt i would stick with the stock pistons. good idea or bad idea?
                • 13525
                #22
                I would keep the stock pistons unless you want to get more milage from the motor. I don't know how long the 11.5:1 will last but it certainly would make more power.
