3500 fiero failure update
  • merlot566jka
    • Nov 2006
    • 570
    it was a piston, #4. it seems as tho the piston broke or the wristpin did. either way there is a little bit of contact between the piston and head, but not enough to even score the head. the valves are strait and not leaking. there are no valve marks on the face of the piston. you can push the piston down into its bore and feel it pop or click before it moves with the crank. it does, however, move with the crank when the crank is turned.
    there is no gouging of the cyl liner and no damage to the cross hatching.
    so i need a new piston and a rod. there is no metal in the oil, so i assume the crank is fine.
    i havent gotten any further apart, just one head off.
    2012 Chevy Sonic Turbo 6spd
    • 9191
    I have 4 piston/rod combinations here from a 3500 if you need them. Just let me know...
    • merlot566jka
      • Nov 2006
      • 570
      ill pay shipping.....or I can pickem up on tuesday next week
        • 9191
        Can you make it to Tulsa on Saturday? I'll be there in the afternoon, and could possibly meet up with you somewhere. How many do you want? I'll try to get pictures of them prior to then.
          Live life 3.7mi at a time
          • 4555
          DOH! You may have beat me to it, lol.
            Wow good news hopefully that's the only part that failed and you can be running down the road again soon!
              • 13534
              Lucky there is no other damage! Pics
              • gpse3400
                • 1460
                I've had piston break before but it was the skirt that broke..In my case.. my 1st engine rebuild...too much piston and not enough cam.. once I figured that out with the help of some people on this board and you all know who you are....I couldnt save it fast enough...Detonation galore...Engine was all torque and no HP.
                Lorenzo
                • merlot566jka
                  • Nov 2006
                  • 570
                  unfortunatly i cannot make it on saturday...ill talk to my wife, maybe i can send her up there. i need these pronto....
                  i may be free sunday or tuesday, if need be ill drive out to where you are. i can make it today.....
                  • merlot566jka
                    • Nov 2006
                    • 570
                    • Younggun88
                      • Feb 2008
                      • 36
                      really good to hear. Your build make me want to start my Turbo 3500 Fiero build.
                        I hope you get it running soon. I'm curious as to how fast it is (like 1/4mile or something). It sure looked fast as hell in the video!!!
                        Did you ever figure out why it was dumping gas into the oil so bad? Leaky injectors??
                        • merlot566jka
                          • Nov 2006
                          • 570
                          no leaking injectors....
                          bad news...#4 had no bearings on the rod....NONE!!!!
                          all the rod bearings are shot and the crank has significant wear on #4 rod journal. so i need a crank kit... any one know where to get a crank kit for a 3500???
                          • merlot566jka
                            • Nov 2006
                            • 570
                            ok screw a crank kit...i need a shortblock
                              • 9191
                              So you are up for a road trip on either Sun or Tues? Or did you say something out coming today? My 3500 shortblock is in pieces, but could probably be put together or thrown in a box or 2 relatively quickly. I'll PM you with my numbers if you want to discuss it.
