250Hp 3400
  • 3.1cutlass
    • Feb 2007
    • 101
    250Hp 3400
    Would this be possible N/A? I am not very familiar with the 3400 but i am thinking up a new project and want to use the 3400. What kinds of modifications do the 3400 respond to best for me to achieve that number?
  • silvergtjrad
    uber slow grand am
    • Feb 2007
    • 302
    Sure, its possible. A ported 3500 top end, along with a cam, and raised compression will get you close, if not all the way there. Headers and all of the bolt on goodies will probably be necessary as well. Gimme about 6 weeks and I can let you know
      Live life 3.7mi at a time
      • 4555
      I'm hoping for 250whp and that's a 3.4 with a 3500 top end and 11.5:1 compression.
      I recently sold a 3500 block to a Midget racer who got 340hp out of a 3400.
      • 3.1cutlass
        • Feb 2007
        • 101
        Just from doing some reading around the site with 3500 top end and 3.4DOHC pistons i would be looking at around 12:4:1 compression?
          • 13531
          That was with a .040 overbore. You would have close to that though with other bore sizes on a 3400. Camaro pistons would be in the 11.5:1 range.
          • 3.1cutlass
            • Feb 2007
            • 101
            Ok cool thanks.
            • rsisbetter
              • Mar 2006
              • 151
              iron head 3.4 pistons, in a 3400, w/3500 top end will yield 11.5:1 cr?
              • Alxsmt
                that one guy
                • Feb 2007
                • 725
                my goal is 250whp, not sure if im gonna make it but i hope i get close
                i think 250 is a magic number lol
                • sprucegagt
                  Old School KI
                  • May 2005
                  • 703
                  I keep wondering if the cylinder pressures from this setup would be too high for pump gas. Has anybody measured there static compression with this setup?
                  Your local OBDII moderator
                  2000 Grand Am GT w/ WOT parts
                    • 13531
                    Its been ran on pump gas so I know it isn't too much. Just need to tune
                    • johnnymossville
                      • Jul 2007
                      • 255
                      3400 with 3.4 iron head pistons, p&p 3500 heads and LIM/UIM, 65mm TB, 210/215 dur-531/531 lift WOT-TECH cam and I'm looking for 250 whp running on 93 octane Shell gasoline. Although I can get 100 octane Turbo Blue if it is needed to get bigger numbers. The new Cadillac v6 is running 11.3:1 on 89 octane accorging to Road and Track mag.
                      • mfuller
                        Mr. Common Sense
                        • Nov 2003
                        • 374
                        Bear in mind that you are referring to the DI (direct-injection) motor, which injects the fuel at much higer pressues directly into the combustion chamber (instead of the intake port).
                        Direct injection is one of the key things that allows higher static compression on less octane.
                        Matt
                          • 4555
                          11.5:1 is not that high for AL heads. A freind of mine has an El Camino with a 327 TPI/DFI running 10.5:1 on 87 octane, and has been since 1990.
                          • mfuller
                            Mr. Common Sense
                            • Nov 2003
                            • 374
                            It must be tuned well. Impressive.
                            Matt
                            • geoffinbc
                              Iron Head Enthusiast
                              • 5831
                              Not necessarily. Cam choice has an enormously huge impact on cylinder pressure. The more overlap you have the less cylinder pressure you will build.
