Scratch that Here it is *pistons please
  • john_V63400
    Banned
    • Feb 2006
    • 409
    So I scratched the last build (high compression bored .060) basically cause I am loosing my job, both me and my girl, we work at the same place and been there along time, but there sold the land to developers! Spending a quoted $3800 on a stage 3 kit from milzy is out of the question now.
    I baught a stock engine from a 2002 Aztek with 15K miles.
    Will this engine drop right in?.............. I hope so, lol, no seriously will it?
    I have read you can just swap out the 3.4 DOHC pistons to get a higher compression
    What year and what models of pistons should I be looking at to buy. I found these.
    http://cgi.ebay.com/ebaymotors/ws/eB...link:middle:us
    Wil they work, and anyone know the compression increase?
    I dont like the power of a stock GA 3400
    So far i have.......
    The other guy headers
    Brola cat back
    Comp Cam valve springs
    Milzy push Rods
    65 RSM throttlebody
    Ported upper and lower intake plenums
    28lb injectors
    taylor 8mm spark plug wires
    I want
    DOHC pistons for a bit higher compression for some thump
    And a stage 2 or stage 1 cam from here with stock heads
    So what pistons am I looking for? anyone have some for sale?
    Live life 3.7mi at a time
    • 4555
    You can use Camaro 3.4 piston as well for higher compression, that's what I'm using.
    They'll be for sale in a few months when I boost the engine again
    • G-U-NOT
      Banned
      • Jan 2006
      • 158
      What will the new CR be on a 3400 with 3.4 DOHC pistons?
      What about the CR on a 3400 with 3.4 camaro pistons??
      • john_V63400
        Banned
        • Feb 2006
        • 409
        But will those Pistons work...the ones with the link. And what year camaro
          93-94 3.4l camaro pistons. The DOHC ones are really high ratio IIRC. The camaro ones are a bit more reasonable.
          • geldartb
            The Situation
            • May 2004
            • 1994
            you cant just drop the camaro pistons in and forget about them youll end up with a 13.1.1 CR with stock 3400 heads and head gaskets.
            if you use 3500 head it brings it down to 11.5.1. i was looking into using the ironhead pistons in my build but didnt really nail down a combo that would work good.
            99 Grand Am GT
            1357 cam 227 233 .050 dur
            515 515 lift 112 lsa
              • 4555
              You're right! I re-read the first post and realized John's using 3400 heads.
              The ratio isn't changed that drastically. Camaro pistons are 8cc, DOHC's are 5cc IIRC.
              • john_V63400
                Banned
                • Feb 2006
                • 409
                So what pistons do I buy to drop in??
                • silvergtjrad
                  uber slow grand am
                  • Feb 2007
                  • 302
                  Stock is the only thing that will drop in. Custom is the only other way to go if you want to change compression correctly. Using either ironhead 3.4 or DOHC pistons gives you poor quench and ultra high compression without 3500 heads.
                  I wanted to do this as well, and as geldartb found, there isnt a good combination of parts to use. What I ended up doing, is getting custom pistons made.
                    • 4555
                    Quench is poor with either gaskets, really. The Camaro pistons have a .0095" deck height and come with .040" gaskets making a .0305" quench. .060" gaskets makes .0505". There are .045" gaskets available I believe, though, they would be perfect.
                    Yes, very hight compression with 3400 heads vs 3500 heads *but* you can turn the 3400 combustion chambers into 3500 chambers with a little patience
                      • 13534
                      Please do not start multiple threads for the same topic.
                      • john_V63400
                        Banned
                        • Feb 2006
                        • 409
                        please stop your wining!
                          • 13534
                          Ok, ill just give you a warning then when you do it instead of asking you to stop. Way to be mature.
