i've read and searched and have heard 2 different opinoins. do not tell me to search, please! 1995 camaro 3.4,,, if i want to put on 3100 (1998 ) model,,, heads and intake on my car i have to change out the pistons too??? i thought i read with some swaps u don't have to change too much? ben, help.....or someone who knows thanks,,,,,new dude,,i've been reading thse forums since december thanks
let me get this straight?!?
The combustion chamber on the 3100 aluminum heads are much smaller than the iron heads on your 3.4. If you put them on your block, your compression will jump through the roof. That's why the pistons would need to be changed for 3400 SFI pistons.Franz
1990 Z24-NA 3.1L
14.72 @ 92.24 MPH
14.89 @ 94.92 MPH
The boost is coming....
You will need tuning anyway, so once that is sorted out, the stock pistons can be used. The compression with the 3500 top end isn't too bad. Its usable with the 3100 or 3400 heads, but 3500 would certainly be the best. 98 3100 aren't my choice. 2000+ 3100 or 3400 for heads, as they are better casting quality and have a 1mm larger intake valve than the 98 3100.Ben
Yes, just swap in the 3400 pistons/rods.. then put the 3400 heads, UIM and plenum on with the propper gaskets and the easy work is done. you'll have to use the 3400 headgaskets, not the 3.4 Camaro ones.
I'd also suggest that you swap in a Crane H260-2 cam while you can, It will make better use of the new top end then your stock cam will.
