@#$%ing wiseco!
  • Alxsmt
    that one guy
    • Feb 2007
    • 725
    @#$%ing wiseco!
    so i FINALLY order my pistons a week or so ago and today i get a package, i didnt read the label but i open it and cant figure out what it is (cylinder shaped object in a lot of bubble wrap) so i read the paper instead of unwraping it. it says
    Dear Sir,
    i am sorry for the inconvenience you have gone through but at the present time, wiseco is not in a position to take this type of order. our engineering department is maxed out right now and we cannot accept jobs that have samples with domes on it.
    IF i had known i would have saved you the trouble of sending this in. if someone told you to send this in, im sorry that this information was not up to date.
    you may want to send this to our sister company JE pistons in california, but i would suggest removing the rod from the piston before you send this out
    Best regards,
    John Levis
    Automotive product mgr
    they sent me my sample piston back with the combustion chamber mold on it. which they told me to do... WTF! this isnt cool. i didnt even get my order form back which had all my info on it, thank god i made copys.
  • kflo 93 gt
    Bangin' Gears
    • Nov 2003
    • 238
    WTF are you trying to get made? You've been having problems for over a year now... I mean I know 10.5:1 pistons... but what is the hold up?
    This is ridiculous on multiple levels, not just on Wiseco's behalf.
    Honestly you should just suck it up and run something already made.
    14.60 @ 96.33 for now...
    • Alxsmt
      that one guy
      • Feb 2007
      • 725
      just simple 10.5:1 compression pistons. yeah its retarted!! one shop screwed me over, another decited to find stock replacement pistons that would be lower compression than i wanted, then i decited to do it my self.. after i got the form filled out the first time i decited to polish and CC my combustion chambers, that took a long time... so once i got that done i decited to have a shop acually measure everything on the engine instead of going with stock specs. turns out my rod eye is oversized too much to go with a stock pin, decited to go with ford size pin and have my rods bored a LITTLE so they would fit..
      after last racing season was over i wasnt in a hurry to get it done. this season crept up on me..
      and i have a LOT of schooling im doing each trimester and working so i dont have too much free time...
      im just set on that compression ratio for some reason lol. i wont settle for anything else
        • 13533
        Why don't you modify 3.4 DOHC pistons? They are much thicker on top than the pushrod pistons. I plan to cut the domes off a set of .030 over that I have here, but won't know what compression that gives for a while.
        Just an idea.
        • Alxsmt
          that one guy
          • Feb 2007
          • 725
          well i was thinking about going that way with the first pistons i got, which were those. i had them measured and i was told there wasnt enough metal there to mill them...
            Wow is 10.5:1 really that important to you?
            • Alxsmt
              that one guy
              • Feb 2007
              • 725
              yeah for some reason it is lol. im set on that compression ratio... i know im psyco
              just gotta call JE tomorrow and figure out what some of things on there forms are asking for, then i get to place my order!! these are like the last thing, heads are 100% complete, block has been ready for a long time, have all my parts (minus the timing chain and new radiator and clutch)
                Just throw in some camaro pistons. Less compression than DOHC ones so you should be decent with 3500 heads. A little more than you want but tune it well you should be fine. Do the camaro ones have enough material to lower it to 10.5 on 3500 heads?
                • Alxsmt
                  that one guy
                  • Feb 2007
                  • 725
                  those are still too high for me (i think it was 11.5:1 with those pistons), ive been told that higher compression will be harder on the engine. i want it to last as long as possable. besides foged pistons are just cooler
                  i think im set! just talked to the guys at JE, all the info i couldnt figure out i dont acually need to give em, and they dont need a mold of the combustion chamber!! so i can just fax or email them my order
                    How much?
                    Higher compression is harder on your starter too LOL.
                    • Lilchief
                      • 87
                      Have you tried Ross pistons? That's what I have in my 3.4pr. 9.8 cr on 6" rods with cast iron heads. I'm wondering how that would work with 3500 (5.9?)rods and the smaller 3500 head chambers. Just an idea you could kick around. Tell us what you come up with.
                      • Alxsmt
                        that one guy
                        • Feb 2007
                        • 725
                        i think they were listed 750 on there site, but idk if that includes rings and pins. it seems like they quoted me like 900 when i was shopping around a while back
                        and yeah i looked into ross a bit, the form seems confusing to just look at!
                        BTW the form was faxed at 1pm on monday!!! ive been in a good mood all day lol
                        • GinoBeats
                          • Mar 2005
                          • 145
                          Weird, faxed my info sheet and talked to them over the phone 3 years ago for my 11.7:1 pistons and I had a forged set sent to me about a couple months later
                          http://www.v6z24.com/registry/ginobeats/
                          http://www.v6z24.com/registry/ginobeats/2
                          • Alxsmt
                            that one guy
                            • Feb 2007
                            • 725
                            update
                            JE just called me to let me know they got my fax and asked me if i still wanted to go through with this, or course i said yes. they gave me a rough estimate of 820ish and there about 4 weeks out.
                            THEY ARE STARTING THEM TODAY!!!!
                            what a great company
                              Wow, please tell me these are forged or something else special otherwise I'm going to say you are throwing your money away for just a little bit of compression.
