Bearing Numbers
  • zofo61
    Banned
    • Oct 2005
    • 436
    Bearing Numbers
    What are the best money can buy and the numbers for:
    Rod Bearings
    Main Bearings
    Cam Bearings
    Thanks Guys
    Chris
    • 13525
    I used ACL but I don't have the part numbers.
      Live life 3.7mi at a time
      • 4555
      I used Clevite77 bearings, but I also didn't keep the part numbers. I might have the boxes at the shop still.
      • zofo61
        Banned
        • Oct 2005
        • 436
        Also.........I lloked on Summit and in the Clevite series they have the stock and then under sizes.....why would you use an undersized bearing?.
        Ben, I looked on the ACL site and like what I saw as far as the design of their bearings.however..I didnt see an aplication for the 3.4?
        • silvergtjrad
          uber slow grand am
          • Feb 2007
          • 302
          If the journals are damaged and the crank has to be ground down, the journals will be a a smaller diameter. You will need to use a smaller diameter bearing then to get the proper clearance around the crank.
            • 4555
            Yep. My crank is .010" undersize in the 3.4/3500.
            The 3.4, 3.1, 3400, 3100, and 86-up 2.8's all use the same bearings.
