Head Gasket Set
  • 94GAblazed
    • Mar 2004
    • 11
    Head Gasket Set
    Since i blew my head gasket and when i got down to the heads to see how bad the gasket was i come to find out that its 75% gone. (wierd) but othe then that is there a good aftermarket gasketset out there other then the stock ones from my local murrys auto store.
  • 94GAblazed
    • Mar 2004
    • 11
    well i thought i might as well just ask all the question in one thread so, here they come. Ok for the cam what one should i get?
    http://www.cranecams.com/?show=brows...tType=camshaft
    and then on the left it show related parts, are those the part that i'm able to use with my engine? ( 3100 )
      • 9191
      There currently isn't an aftermarket cam for the 3100s. The only thing you can get (for at least a few more months) is a regrind. The reason they list the cam there is because some cars (Cavaliers, Luminas) kept the old 3.1 into 94, while most of the other cars got the 3100.
      • ikessky
        • 614
        As far as the gaskets go, take a look at http://www.pickproparts.com. They have Fel-Pro gasket kits on there for a decent price. I just used them on my '95 3100. Actually, I still have the exhaust manifold gaskets and valve stem seals if you want those. I'll give you a better price than anywhere out there!
        • xxrollin
          • Feb 2004
          • 102
          And the reason there are no cams available for the 3100-3400 is because these use an assembled roller cam and the older ones like the ones your looking at are the older flat tappet cams. You can use a flat tappet cam in a roller block. Your best off using a regrind for now till someone comes up with a core for a roller cam. Anyone should be able to re-grind your cam and some will even ask for your pushrods so they can get you new ones that will match with your cam.
          • 94GAblazed
            • Mar 2004
            • 11
            well i found a company online that can make cutoms cam which is not to bad. Not sure on the price i will post the web site when i get home. What about roller rockers and lifters?
            • ikessky
              • 614
              You can swap the roller rockers from a 96+ engine, or you can use some narrow bodied rockers from Crane or other manufacturers. Check the threads because there was just a post about someone putting the Crane's on his engine. You should already have roller lifters unless I'm missing something.
              • geoffinbc
                Iron Head Enthusiast
                • 5831
                Crane rockers take some intake manifold modification to fit a 3X00. Lloyd and I were the forst to do it. But it really wasent that hard.
                • xxrollin
                  • Feb 2004
                  • 102
                  Call Crane or ARP, they have a stud with the 10mm for the head with a 3/8's stud up top. I gave up on trying the swap, mainly because of having to use the guide plates. The self aligning rockers might be a bit better. I like Comp's mag. rocker arm. I have a set of these in the self aligning in 1.6 and the harland sharp rocker arms, both are full roller rockers with roller tips.
