WOT-TECH part question
    IIRC midnight ported his out to 75mm cause the 4.3 tb he got was a bored out "race" version anyways. You should be able to bore it out that far, but there's a lot of work boring it out down in the neck area. You can tune for it but the TB will be very touchy and go WOT before the plate is fully open. It won't have very good "road manners", but in a modified vehicle who cares as long as it's not a daily driver or anything I guess.
      • 13534
      I don't even have an option to do this to a 3500 manifold yet. I won't be opening up the whole neck either. May as well go true custom at that point. 65 to 75 quite a bit of material.
      • G-U-NOT
        Banned
        • Jan 2006
        • 158
        So Dave's TB is a 4.3 thats bored 5mm??
        Im not worried about it bein touchy and all that, it's only gonna be a weekend joyrider/track car anyways!
        Once I get everything done and swapped in Im gonna need Ben to reburn the chip I got from him awhile ago anyways!!
        I still have my original 60* chip in my computer for the stock 3.1L!
        Couldnt you just do it for me anyways and figure out a price?
          No, Dave's is a northstar, 75mm stock. I was talking about midnightriderz24's 4.3l TB when he had the 3500 plenum. IIRC he got a 4.3L one off ebay that was a performance bored out version. Stock 4.3l is 70mm
          • G-U-NOT
            Banned
            • Jan 2006
            • 158
            Ok, Thats what I thought but I was confused from what you said...
              yep, lots of material to remove.
                • 13534
                #22
                Sure, but I would have to do it first to know what I would charge. Its 66mm stock and I can only blend in a short distance on the manifold so probably 20-25 as a guess right now.
                I don't know what kind of reburn I can do for what you are building. Sounds like custom tune territory to me.
                • G-U-NOT
                  Banned
                  • Jan 2006
                  • 158
                  #23
                  Thats not bad, it's worth it to me!
                  Im just going to need something to run my 3400.
                  Its not going to be turbo right away, I wanna break in the engine first and get it running perfect before I start putting boost thru it!
                  • G-U-NOT
                    Banned
                    • Jan 2006
                    • 158
                    #24
                    Would it be possible for me to just send you my 3500 plenum and the TB and then you can just put the adapter on and port match everything, then figure out a price for everything once you're done? I would also want you to port the whole thing out as well....
                      #25
                      If going boost why not just use a 3400 TB? Turbo with a smaller TB isn't that bad compared to something like a roots style blower where the TB can be a restriction where the S/C is trying to breathe in air through it. Like if your charge pipe outlet on the turbo is 2", well 56mm TB is 2.2" so I don't see a restriction really...
                      • G-U-NOT
                        Banned
                        • Jan 2006
                        • 158
                        #26
                        Well for 1 thing, I dont have a 3400 tb! Besides, a 75mm throttle body is better! If stock was big enough, NOBODY would EVER upgrade the tb on ANY CAR....
                        Also, my piping will be 3"!!
                          it's not about upgrading for the sake of upgrading.. you upgrade the TB to deliver the ammount of air your engine needs. I changed mine from 65mm to 75mm because at WOT i was still pulling vacuum and only hitting 90-95% MAP.
                            #28
                            You are going to run 3" charge piping from the turbo and intercooler ??? That's not needed...
                            • merlot566jka
                              • Nov 2006
                              • 570
                              #29
                              g-u-not..... do some research man!
                              i can help ya. if u want.
                              u dont need anything bigger than stock size tb on ur engine. piping shouldnt be any more than needed...so 2.25 would be more than enough. bigger sint always better.
                              remember when air flows into a space with volume, speed decreases, pressure rises as toes temp.....thats what a plenum does, essentially your 3 inch charge pipe will reduce your imediate boost, raise your intake temps and have more posibilities of popping off under boost.
                              Last edited by merlot566jka; 04-06-2008, 10:30 PM. Reason: i took pills and drank beer tonight
                              2012 Chevy Sonic Turbo 6spd
                              • G-U-NOT
                                Banned
                                • Jan 2006
                                • 158
                                #30
                                I realize that, but I dont want to have to switch things up down the road and port it out again and all that!
                                Why not? Every single turbo car I've worked on or helped build always had 3" pipes getting the air in and also getting the air out!! Any aftermarket intake you get is usually going to be 3", and thats for N/A cars.... so why wouldnt 3" intake piping be good for boosted apps???
