if mating a LX4 to a 5speed what flywheel do you use would any neutral balance from the 2.8-3.4 work?
3500 LX4 Flywheel
Tags: None
Well you still need neutral balance. Not sure what will bolt up and work though... Probably any 2.8/3.1 FWD mpfi fly wheel.sigpic
yes the fwd 2.8/3.1 flywheel
look at an 88 fiero, 88-92 cavalier, berretta, etc etc3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe ALL FOR SALE (minus the car)
2012 Chevy Sonic Turbo 6spd
the difference could be the balance3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe ALL FOR SALE (minus the car)
My bad the engine is the LZ4 anyway the 88 fiero is the one i will use as it is going into a fiero.
