about rockers
    TBH, I have never had problems unbolting any exhaust on any of the 60v6's. Never had stud 1 break or anything. Now Fords.... unless you have a torch handy, forget it. But yeah, GM's exhaust studs/nuts have always worked out great for me without having to heat them up.
    • torq455
      If I only had money!!!
      • 1615
      headers? hell yes! min of 15 hp gain there! really woke up my GASE. you can look for used headers on grandamgt.com . got mine there with the cat for $460.
      Andy
      fastest 1/8: 10.19@ 67.17
      fastest 1/4: 16.16@ 82.70
      • IanSzgatti
        • Oct 2006
        • 519
        i feel inspired all of a sudden
        • Ray Hamilton
          • Feb 2007
          • 239
          I have a problem I can't get to the bottom of concerning rockers. I put a set of CompCams 1.52 rockers on my hybrid 3.1 (see signature) and it has had a serious idle problem since. I've checked for vacuum leaks, reset the the IAC, replaced the IAC, checked the TPS voltage and still it won't idle right and it will surge at part throttle and idle way up to 2000 intermittently, all since I changed the rockers. I also readjusted the rockers. I am of the assumption that with my cam profile and what little addition to the lift the rockers may or may not have created that it's making the ECM go ape-shit. I'm at the end of my rope, ideas please??? (204-214@.050, 270-280 adv., lift-.420, .443, 107-117 centers). It ran fine before the installation of the rockers with one problem during installation,a push rod slipped off a rocker and bent causing the valve to stick open and backfire. It only ran like this for 20 seconds before I shut it down.
          '86 S10 Blazer 4WD, '87 2.8 with 3.1 crank and pistons, A.R.I. "Stage 2 Cam", Iron Heads with stiffer springs, Holley TBI, Manifold bored to fit the TBI Base(4.3 size), Fiero Covers, MSD Coil, DynoMax Muffler and 2.5 Tailpipe, no cat, Auburn Limited Slip, 3.73 final Drive. 700R. '85 Fiero GT 3.4 Hybrid, relieved top intake and exhaust, 57mm TB, Auto. 3.06 final drive.
            • 9191
            Not that you want to do this, but have you thought about swapping back to the old rockers and seeing if the issue is still there? I just find it hard to believe that going from (I'm assuming) 1.5 to 1.6 ratio is going to cause the ECM that many issues.
              • 13534
              #21
              How do you readjust the rockers?
              • torq455
                • 1615
                #22
                why would you change to a smaller ratio and go with the roller tips instead of staying with the stock 1.6 ratio and roller fulcrums?
                maybe you bent a pushrod.
                Andy
                • Ray Hamilton
                  • Feb 2007
                  • 239
                  #23
                  Actually it's 1.5 to 1.5. The next thing is to switch back as you said. Today I put on a different TPS and reset it to .51. Things seem better. How long does it take for the ECM to "learn" the new settings? Thanks for the reply.
                  • torq455
                    • 1615
                    #24
                    oops. my bad! should have read your sig like you suggested. i just read hybrid and assumed it was a 3.1 alum head.
                    Andy
                    • Z26-T
                      • Apr 2008
                      • 486
                      #25
                      I've broken two of them... On two different engines pulling the rear manifold off. Exact same spot, both 95' 3100 engines. The top left one cylinder #5, my guess is because of the location with the cross-over. Gets the heat from 2, 4, 6 and 5. But they both broke with it extruding, so was no big deal to pull them out.
                        #26
                        Looking at a 95 grand am 3100, how the hell do you get the bolt off the heatshield that is right behind the trans dipstick tube? Do you have to take the dipstick out?!
