electric water pump
  • MitchPower
    • May 2008
    • 7
    electric water pump
    any one use a meziere or something similar to reduce hp loss either remote or at the place of the original waterpump
  • Z26-T
    • Apr 2008
    • 486
    Honestly wouldn't see the point... You will get a couple hp, but not nearly enough to pay for the swap. For your money buy a under drive pulley, or exhaust or really anything that's already made and is common.
    • MitchPower
      • May 2008
      • 7
      because the a/c compressor and the power steering will be removed and the belt routing is a problem unless theres no water pump to drive
        • 9191
        Idler pullies.
        • RailHomie
          • Nov 2007
          • 24
          Yeah, I've kind got the same problem. Where would you put an Idler pulley? On the side where the Power steering pump used to be?
          • rsisbetter
            • Mar 2006
            • 151
            yes
            a 3x00 timing cover should ahve a hole or boss(s) to add the idlers
            • Wiz85
              N/A all the way
              • Feb 2008
              • 48
              I can't use my PS pump and A/C either, so I machined a pulley out of Aluminum. You could just bu one.
              Eric
