Injectors size on a 3.1 Gen2
  • DirtRacer
    • 21
    Running a Z24 92 on a dirt track. Only have a little cam (420-443) installed.
    Also running a lite flywheel. I have just remark that the spark plug seem to run on the lean side!!
    We are most of the time full throttle. also running a fuel pump from MSD at 40 psi.
    What is the flow rate from the original injector and what size can i go to before having to change a lot of other things.( rules is stock or almost.!!!!)
  • MidnightriderZ24
    • Jan 2005
    • 699
    original flow rate is 17# per hour. honestly the cheapest way for you since youre dirt tracking it is increase the fuel pressure a little..
    [SIGPIC]
    12.268@117... 11's to come!
      • 13525
      40psi is low. Tuning would get your further than bumping the pressure alone.
      • Z26-T
        • Apr 2008
        • 486
        And lucky thing with you, being OBD1 someone should be able to make you a chip.
        • DirtRacer
          • 21
          OK..
          So the OEM fuel regulator is ajustable??? How do you do this..?? What is the max. fuel pressure that the system can hold??
          Would 19lbs fuel injectors be an easy improvement?
          I tried a Superchip and also a JET chips(level 2) but it is not legal. Would a chip made by someone look like the original ? Because for the aftermarket chips it is easy to see that it is not the OEM stuff and you are disqualified.
          Anyway, we have a little gain with those chips but it is not as good as it is supposed to be.
            • 13525
            No, OEM is not adjustable. Those chips suck and are dyno proven at 0-1 hp gain. I could write you a chip on a memcal so it would look like stock but you really need it tuned, not just chipped. There is a difference, as you need datalogs to see what the computer is even doing.
            You may not need larger injectors, but you won't be able to run larger injectors well without a reprogram. About the best I can offer without the car or datalogs is to use my old chip for the mustang 19# injectors on a lunati .441 lift cam (forget the rest of the specs).
