i wanna go 12s...all engine
  • IsaacHayes
    Mr. Orange.
    • Apr 2006
    • 6030
    Nitrous does add oxygen to the mix. That's why you need to squirt more fuel. But yeah it's not "all motor" as all motor is N/A. Some even consider it more of a "cheat" than S/C or Turbo, because your car can't make that power all the time all day long as a normal function, you gotta re-fill that sauce.
    • gectek
      Banned
      • Aug 2006
      • 1472
      yah well if thats the case then all engines are like that cuz u gotta fill them with gasoline
      i dont care, NHRA doesnt think its cheating then neither do i...but ill see where i can get all motor, then add juice.. is what i meant
        Hows 13.08 @ 105.5?
        i only got 2 runs in, place was packed.
        • 01GPGT
          Curse you Red Baron!!!
          • Jun 2008
          • 214
          Hows 13.08 @ 105.5?
          veary nice!
          • hookdonspeed
            • Jun 2007
            • 322
            well, i guess im going to be the bad guy here...
            ive been arguing with myself on what engine to swap into my fiero for a few months now... after going over price to power options, and tunning, etc...
            the 60* engines are out
            ive decided to go with a 90* 3800SC. price per HP, it will be ALOT cheaper.
            with just the swap it will drop me into the 12's, and if i add cooler, cam, injectors, tune, and a diffrent pully, the 11's.
            but i am going to be buying a 95ish car as a daily beater, and prettysure thats going to be a 60*, and i doubt ill keep that stock
            • gectek
              Banned
              • Aug 2006
              • 1472
              #21
              Hows 13.08 @ 105.5?
              was that with or without the cutouts open
              • IsaacHayes
                Mr. Orange.
                • Apr 2006
                • 6030
                #22
                Stock L67 puts a Fiero in the 12s? Are you sure? A 3400 with a turbo would make more power than the L67 I bet. Adding a cooler to the L67 is not that easy or cheap... If you can fab stuff your self, the 60* is the better bang for the buck if you can source the components you need.
                  • 13531
                  #23
                  Originally posted by hookdonspeed View Post
                  blah blah blah L67 blah blah blah
                  thank you for your irrelevant and off topic post.
                    I removed the cutouts.. i had like 2-3" of ground clearance with them, made it really hard to drive.
                    that was with the full exhaust
                      Live life 3.7mi at a time
                      • 4555
                      #25
                      It akes a super charged 3800 to make 20 more hp than a stock N/A 3500, and the l67 weighs a lot more
                      Look at Merlot's build, he got his first 3500 for $150
                      • gectek
                        Banned
                        • Aug 2006
                        • 1472
                        #26
                        yah im going to have to put mine in a diff spot...it hits everything now, only prob is ill have to get a new center section for my borla...oh well maybe someone has a borla that wants a cutout. ill prob get it put right at the end of the first bend...kinda like the straight way out if you know what i mean, then itll give me more room to mount it instead of having all the heat shield there...just a straight pipe comming off with the flange at the end. then the cutout, electric of course...hehe
                        • hookdonspeed
                          • Jun 2007
                          • 322
                          #27
                          isnt merlot still not running right?
                          • 01GPGT
                            • Jun 2008
                            • 214
                            #28
                            ok
                            if you need some parts in abought 3 mounths i'm ditching my 3800 for a 3400
                            • merlot566jka
                              • Nov 2006
                              • 570
                              #29
                              gave the car to my brother. him and darth are getting it tuned. had a small fuel pump hicup. with the new pump, its getting some good pressure now and its time to start the dataloging again. log, send, burn, mail, run it again....then log, send, burn, mail......it never ends
                              2012 Chevy Sonic Turbo 6spd
                              • TurboGTU
                                • Dec 2003
                                • 453
                                #30
                                They used to make 350hp on the tiny 2.8s with 12:1 static compression back in the day. Im sure that can get you close. BUT with a 3500 you'll be way ahead with similar mods. What would be wrong using a Global 24v engine?
                                Im thinking 15:1, solid cam, Nitro? No N2O or boost.
