  • alerored04
    replied
    Originally posted by torq455 View Post
    then go with a 1.8/1.7 combo. you'll gain across the board with a little more lift. no duration change, so no loss anywhere.
    I think I will do that then. Is that 1.8 on the intake and 1.7 exhaust or the other way around?
    All I had to do to get approved for these is to promise to replace her 95 escort with an 03 Saab 9-3 Turbo. Wonder if I will have to buy a house to get a turbo on my car. I am so jealous of her right now.
  • kwhauck
    replied
    Originally posted by kwhauck View Post
    i don't have the ICL? but i have these, am i missing anything?
    Comp Cams special order roller
    230/242 @ .050 duration
    280/294 @ .006 duration
    .577/.577 lift. 115 LSA
    edit ICL is 112, I am working with geteck on this cam card....
  • torq455
    replied
  • alerored04
    replied
    I just got spousal approval on these so I hope they come out soon. That way I car purchase before she changes her mind. I think Ill be going with the 1.7's. I want more lower end so if a combination would help me out more let me know.
  • torq455
    replied
    the comp springs are good for that lift he has plus boost? there have been some boost cams that have a 118 LSA. I believe the LS1's cam N/A has a LSA of 117.
  • gectek
    replied
    boost....needs a larger LSA esp on that big of a dur. even on a 112 that cam would lope. hard. and you would have a problem with blowing the charge out even then. a wider LSA will help keep some bottom end but that is a large cam. the lift is good. those numbers seem to be a little off though. seems kinda strange.
    IMHO i would also look at the spring specs for the higher lift. and what red line you are running to. we have springs for sale that will run up to a .600 lift cam, but at a certain point we tell the .600 guys no, because rapping the spring up that high would cause some issues due to the spring pressure not being high enough.
  • kwhauck
    replied
    yeah the springs are fine and you couldn't get anything close to that duration from rockers. 115 LSA? Interesting cam to say the least.
    can you elaborate??
    replied
  • kwhauck
    replied
    comp cams 26986, it says on the site they are good to .650......
  • RedBird
    replied
    DAMN that's a pretty big cam
    you definately don't need any more lift. what springs are you planning on running?
  • torq455
    replied
    won't change the idle. increasing the duration about 10 degrees @.050 most likely will change your idle
  • kwhauck
    replied
    tell us what they are, and we can tell you what they mean.
  • Russell52
    replied
    Im curious if this will cause the idle to change? Like erratic etc.. or will I maintain my semi smooth idle?
    Russ
  • torq455
    replied
  • kwhauck
    replied
    well that blows......but then again i really don't know what half my cam specs mean so.......
