  • gectek
    I Hate Nose Hair
    • Aug 2006
    • 1472
    #166
    not true....if you are good enough you can do it through the wheel well on some of the fwd cars. ive done it.
    plus this would give the rwd guys that are using the 3400/3500 uppers on their iron headed engines a boost too. they dont have a huge selection in cams. iirc we are roller and they are not. well yet.
    and even when you arent on a max effort NA build....you can get more perf out of any cam (barring ptv problems) with the higher ratio rockers. this is an easy way to get bigger lift for more power than to go to an aggressive duration to keep the ramp rate descent.
    • gectek
      I Hate Nose Hair
      • Aug 2006
      • 1472
      #167
      so again ill ask. who is committed to these rockers. just say you are locked in.
      I know i am. I may even take 2 sets. plus a set for the 3900 malibu.
      • alerored04
        • Sep 2006
        • 126
        #168
        I am unsure still. I need to know how much this will affect drivability with my current stage 2 N/A cam. Just wondering how much gain I will see and how much tuning I will need. With this info I will be better able to make a decision.
        Lots of mods cost lots of $$
        http://www.cardomain.com/ride/2598719/1
        • gectek
          I Hate Nose Hair
          • Aug 2006
          • 1472
          #169
          lift for the most part has no effect on drivability. you will prob see more off seat duration, but it is not going to add more than a couple degrees. it really isnt measured like that, but that is really the simplest way to put it. the only thing you would have to watch is coil bind. you may want to tune a little more on it, because it will have the chance to fill the cyl during the intake event and move more air. you could prob add more timing and it might change the VE a little, but seriously if you have a MAF, it should be able to compensate for that.
          • torq455
            If I only had money!!!
            • Dec 2003
            • 1615
            #170
            locked in. like i said, in the near future, say between 2-6 months.
            Andy
            fastest 1/8: 10.19@ 67.17
            fastest 1/4: 16.16@ 82.70
            • alerored04
              • Sep 2006
              • 126
              #171
              Well if that is the case then I am in about 90%. Just need a guess on power gain on top of my cam.
              • gectek
                I Hate Nose Hair
                • Aug 2006
                • 1472
                #172
                educated guess for 1.7 would say 5-10 across the entire operating range
                guess with 1.8 is prob 10-15 ish.
                staggered ratio would be good too, but kinda hard to say. real world results would depend on so much. cam selection, ramp rate, springs, head flow rate, intake flow rate, exhaust flow, tuning, engine management.
                its really complex. ill say it like this. from what i have seen published and in real life, bolt on a .1 point change in rocker ratio can range anywhere from 5-10 over a stock valvetrain. IF you were using a ball style stamped steel rocker like the SBCs then its even more than that. esp if you jump from a 1.5/1.52 ratio to a 1.7
                • alerored04
                  • Sep 2006
                  • 126
                  #173
                  Well then count me in. If you have any advice on a stagger or sizes or anything I would really appreciate it. I am running ported heads and intakes with comp springs and SI valves on my 1393 cam, along with all the other bolt on stuff.
                  • Nick-G
                    11's or Bust...
                    • Feb 2008
                    • 224
                    #174
                    I'm for sure in for a set.
                    • montess408
                      • May 2006
                      • 391
                      #175
                      yeah i would like a set in the second half of the year. will they be avalible in 1.7 and 1.8 ?
                      i would be interested in a 1.8 set. and there is no need for custom pushrods right ?
                      • geldartb
                        The Situation
                        • May 2004
                        • 1994
                        #176
                        im in for a set too. you can count me in for sure.
                        99 Grand Am GT
                        1357 cam 227 233 .050 dur
                        515 515 lift 112 lsa
                        • SE'sarecool2
                          Gearhead for life
                          • Jan 2006
                          • 76
                          #177
                          Count me in too. I've been wanting better rockers for a long time now.
                          -RUSH
                          • drayrunner
                            • Feb 2007
                            • 61
                            #178
                            If they are in the 300 range and 1.8 ratio i'm in for a set, as far as a delivery date, they just tell you what you want to hear,And yes i did send a email. oh well i guess we should consider ourselfs lucky they are making rockers for the 3100- 3400 motors.
                              Live life 3.7mi at a time
                              • 4555
                              #179
                              Production date on the 8mm heads with 1.7 ratio?
                              I know I'll be taking at least one set of 6 for sure (working on a customer to buy a set of 12).
                              • gectek
                                I Hate Nose Hair
                                • Aug 2006
                                • 1472
                                #180
                                ATM the sets will only be available in sets of 12. that should change after a little bit though. progress is being made rest assured
