The Variable Length runners on the 3900 - What state are the runners in with no power supplied?
3.9L LZ9 engine internal upgrade & performance?
from what i can tell, have been told, they're not actually variable length.... the variable portion of the intake is plenum volume. seems that the plenum can be divided into two equal portions, one for each bank of the engine, or combined into a single large plenum.
pretty sure in a performance oriented setup you want the wide open 3.5 LZ4 plenum with none of the variable junk.... You can port the hell out of them for maximum top end... My 3900 camaro makes gobs of power.11.92 @ 122 MPH 3400 91 Cavalier Z24 Intercooled S/C. -totalled-
what about these mahle pistons?
http://www.jegs.com/i/Mahle/644/LS13...95#moreDetails
Mahle LS1340898F04
Forged 4032 High Silicone Low Expansion Aluminum Alloy
Bore: 3.898''
Pin Diameter: .945''
-4cc Dome Volume
Comp. Ratio @64cc: 10.4:1
Precision Ring Grooves for Included 1.5, 1.5, 3.0mm Rings
Compression Height: 1.340
Weight: 394g
From the specs posted by nated4, if those are correct then it appears this pin diameter is real close, as well as the compression height.
Can someone do the math to see if these are down in the bore too far or up too high with a factory head gasket?
I am going to assume that everything is blueprinted to spec to do the math on these mahle pistons.
3.31 stroke /2 = 1.655
+ 5.9 rod
+1.34 CH of piston =
8.895
The deck height specs are listed as 8.818 which means these pistons would stick up out of the block .077
To get a 0 deck height you would need a CH of 1.263
Now the piston pin diameter for the mahle is .945 and factory piston pin diameter is .942-.943.
It might be possible to shave that .077 off the top of the piston, machine the piston pin down .001.
Of course now to factor in the CR you would have to use 4cc or less since the piston is shaved.
This would net you a zero deck height. If the gasket is .070 when compressed( I have never measured) then that would give a quench of .070
A quick online CR calc states roughly a 12.7:1 Compression ratio with these pistonsLast edited by Guest; 07-25-2013, 10:31 AM.
I think I measured my stock gasket at .053" compressing it with the caliper. However you can order shim gaskets to whatever thickness or buy a spare gasket and remove the rivets and re-stack them.
Check out diamond racing they may have a set of LS pistons that are 'semi-custom' thats what I did for my LZG build. You can use modified buick V6 rods on the stock 3.5/3.9L cranks. I think the buick rods need to be narrowed slightly. The bearing diamters are within .0002" of each other if you compare the tolerances from Clevite. The main problem with most buick rods I've found is that they aren't the right length.
the buick rods are a tad on the narrow side for a LX9, I would imagine the same is true for the LZ engines.Originally posted by NateD4 View PostI think I measured my stock gasket at .053" compressing it with the caliper. However you can order shim gaskets to whatever thickness or buy a spare gasket and remove the rivets and re-stack them.
Check out diamond racing they may have a set of LS pistons that are 'semi-custom' thats what I did for my LZG build. You can use modified buick V6 rods on the stock 3.5/3.9L cranks. I think the buick rods need to be narrowed slightly. The bearing diamters are within .0002" of each other if you compare the tolerances from Clevite. The main problem with most buick rods I've found is that they aren't the right length."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Very scientific.Originally posted by NateD4 View PostI measured my stock gasket at .053" compressing it with the caliper.
I know this is almost 7 years old, but what ever happened to the engine? ever run? dyno?"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
