Ported 3500 heads/manifolds on a G6
    • 13525
    initial dyno comparison but I don't think its tuned right now judging form the dyno sheet and AF. About 10 whp gain and 7 foot pounds of torque from the numbers I caught. The pics are a bit big and the rpm range isn't the same between runs and the owner will be dynoing again after the ECM has had time to learn again.
  • onefastV6
    • Sep 2005
    • 880
    Good work, a 10 HP gain on the dyno with out tuning for the mods is impressive.
    It would have been interesting to see if there was any KR present during the runs.....
    2000 Grand Am GT
    2011 Chevy Impala
      • 13525
      Yeah, tuning ability would be key. I am anxious to see how the dyno tuning goes with whoever does it.
      • rsisbetter
        • Mar 2006
        • 151
        whats the "WCF" ?
          • 13525
          with correction factor.
          • rsisbetter
            • Mar 2006
            • 151
            does that mean tuning? er, self learning? must be a LATE model obdII thing?
              • 13525
              Its need tuning, not "learning".
              • leong6gtp
                • Apr 2008
                • 34
                oh yeah newbiestyle's ride. im also very interested to see what the numbers are after tuning.
                • gectek
                  Banned
                  • Aug 2006
                  • 1472
                  WCF is weather correction factor....they try to factor in weather to give a more consistent idea of power output of X vehicle. That way all dynos that use this are corrected for Sea Level
                  • rsisbetter
                    • Mar 2006
                    • 151
                    hmm, when i went to the dyno the other week, it said on the sheet: correction factor; 1.03. does that mean 1.0 is sea level, er?
                      • 13525
                      from what I have been told, yes 1.0 would be 68 degrees F, 0 feet elevation and no humidity. 1.03 sounds reasonable considering I was told every point was a lot t (1.1). If you don't know the correction factor, then the dyno operator could have used a higher factor to make the engine seem more powerful than it really is.
                      • gectek
                        Banned
                        • Aug 2006
                        • 1472
                        well we save that for the mustang boys...lol
