2.8L valve seals and springs
  • bbeck
    • Jul 2004
    • 158
    I'm looking at doing a set of valve seals on my 2.8 as it is beginning to smoke more and more. I did a compression check on the motor just a couple weeks ago to see if it would be worth doing, and everything is fine. So, I'm looking to replace my valve seals and figured I may as well do a set of springs while I have everything apart and possibly some higher ratio rockers (if there's some cheap replacements). What are my possibilities?
    88 Beretta GT
    69 Corvette
    79 Mustang Ghia
    95 Cutlass Convertible
    for rockers.. a set from a 94/95 3100 V6 is a direct bolt-in and they're 1.6 ratio so they'll give you a bit more lift.
    If you abuse the car at all i'd pick up a set of LS1 valve springs, spring seats, locks and retainers from GM and do the beehive swap. Beehive style springs are much better than the old style.
    you'll still be able to use stock replacement seals as well.
    • bbeck
      • Jul 2004
      • 158
      Sweet, thanks for the info Dave. What's the best source for the LS1 valve springs and hardware I'd need?
      88 Beretta GT
      69 Corvette
      79 Mustang Ghia
      • bbeck
        • Jul 2004
        • 158
        what is the stock rocker arm ratio on the 2.8?
        88 Beretta GT
        69 Corvette
        79 Mustang Ghia
            I'd go through www.gmpartsdirect.com, just look up everything for a '00 Camaro LS1
            It might take a week or 2 to arrive but they usually have the best prices.
            • bbeck
              • Jul 2004
              • 158
              thanks, i'll look into them.
              88 Beretta GT
              69 Corvette
              79 Mustang Ghia
              • bbeck
                • Jul 2004
                • 158
                the one's that are 2.13 a piece?
                88 Beretta GT
                69 Corvette
                79 Mustang Ghia
                • bbeck
                  • Jul 2004
                  • 158
                  so, I just got the car back out for the summer and got the valve seals. I was wondering about those springs again, so if someone could help out with part #s I would really appreciate it.
                  88 Beretta GT
                  69 Corvette
                  79 Mustang Ghia
                  • bbeck
                    • Jul 2004
                    • 158
                    So, I dug up some part #'s and here is what I have:
                    12589774- Engine Valve Spring 2.17/per
                    10166345- Engine Valve Spring Cap Key 1.48/per
                    10166344- Engine Valve Spring Cap 2.18/per
                    but I can't find part #s for the seats??
                    Now, I also have an option of buying a set of 02 ws6 stock valve springs, retainers, seats and seals for about half the price
                    88 Beretta GT
                    69 Corvette
                    79 Mustang Ghia
                      Live life 3.7mi at a time
                      • 4555
                      I thought Ben stocked most of this stuff? No wait for shipping
                        • 4555
                        Actually I have a set of 16 LS1 springs here if you want them...
                        • bbeck
                          • Jul 2004
                          • 158
                          What seats do I use with the LS1 springs?
                          88 Beretta GT
                          69 Corvette
                          79 Mustang Ghia
                          • WrathOfSocrus
                            • Jan 2008
                            • 318
                            i could be wrong but i think the part labeled shim is the seat
                              • 4555
                              Yup.
