Finally finished
  • MidnightriderZ24
    • Jan 2005
    • 699
    #121
    well since life gets in the way of these kinds of things.. its been going very slow, but its getting done the way i want it to. got my rest of piping for the down pipe and exhaust, v-bands, braided flex.. i gotta get my stupid welder fixed...its really holding up this project... I also got the charge pipes ready for powder coating, iat hole tapped into the pipe. got the , had to modify 2 pipes to fit the blow off valve. since i want all the lines on the engine to be braided, i set on my quest to tap everything for fittings. front valve cover pcv was tapped using 3/4'' npt, rear breather vent 3/8'' npt, plenum 3/8'' (for pcv), 1/8'' (vac lines). Since i deleted the LIM heater pipe and tapped it for the cts, i want to run a braided hose from the water pump outlet to my heater core. from my picture u can see 3/4'' is just a hair small ( i cant find any 1'' NPT to -10an). im thinking 1'' npt adapter to 3/4'' adapter to -10an for my heater hoses. im sure ill have updates soon.. :-)
    [SIGPIC]
    12.268@117... 11's to come!
    • MidnightriderZ24
      • Jan 2005
      • 699
      #122
      ive been kicking around the idea of using the water jacket plugs on the block by cyl's 5,6
      Now my idea is to use 2 -4 braided hoses from the water pump main outlet, to the jacket holes to help with the heating of 5,6 (kinda like the 3500 has but with oil squirters). does anyone think this will help cooling by pumping coolant to the holes or is it a waste of $$
      [SIGPIC]
      • CNCguy
        Bisong eater :P
        • 1017
        #123
        Rerouting coolant to improve cooling has been done on many engines and should work here. It would help cooling on cylinders 5 & 6 and reduce the chance of detonation. Just my opinion but I would pull the coolant from each side on the front cover where the coolant enters the block for more balanced flow and wouldn't go too big with the hose size so flow isn't hurt to the front cylinders.
        MinusOne - 3100 - 4T60E
        '79 MGB - LZ9 - T5
        http://www.tcemotorsports.com
        • MidnightriderZ24
          • Jan 2005
          • 699
          #124
          honestly i think the engine is pretty much good, im worried about trans issues and axles..
          [SIGPIC]
          • Barry
            95 Beretta LG8 Action
            • Aug 2007
            • 269
            #125
            Looking good!
            95 Beretta- Lg8 Daily Driver
            • torq455
              If I only had money!!!
              • 1615
              #126
              nice work!
              Andy
              fastest 1/8: 10.19@ 67.17
              fastest 1/4: 16.16@ 82.70
              • 89jyturbo
                • Feb 2006
                • 10
                #127
                What clutch are you palnning to use?? I've had enough trouble with my stock 3400 at 13-16psi of boost, can't imagine what you are going to find that will pull down the power you should make. Clutch issues kept me out of the 11's for at least a year. What I have now is still borderline. I have to use the 2-step to launch so I can dump the clutch (if I try to slip it at all on launch the clutch is useless the rest of the run).
                '89 Z24 3400 5-speed
                TO4E 50-trim/T3 Stage II turbo; 13psi
                Quarter mile: 11.95 at 118.7mph
                www.khturbo.net
                • SofaKingWeToddDid
                  • Jul 2009
                  • 785
                  #128
                  every time i look at that motor i get a little excited. god that thing is sexy and looks like its ready to go (just about?)
                  • MidnightriderZ24
                    • Jan 2005
                    • 699
                    #129
                    clutch is a bully stage 4. we'll see what it holds lol. thanks for the compliments. i plan on hiding the wiring harness, coating the headers, crossover and downpipe yet. slow steps.. just need a fuel system and decide between megasquirt or code 59
                    [SIGPIC]
                    • Barry
                      • Aug 2007
                      • 269
                      #130
                      If you do go MS, go MSII. Its just worth it in the long run. However, you can upgrade a msI to msII for 90 bucks. Thats what I am going to do. Its so easy to tune.
                      • Monzsta
                        • Jul 2007
                        • 132
                        #131
                        Go Megasquirt... It's so much better than a stock coded ecu in all aspects.
                        '97 Chevy Lumina, '99 LA1, ported heads, manifolds, 2 1/2" exhaust, k&n filter, 180* stat, A/C delete, Ram air, 3600 FAFB converter, 4T60E shift kit, DHP Power Tuner, AEM UEGO, MegaSquirt II/Extra
                        1/8 mile 9.72@75 mph, 2.0 60 foot
                        • 89jyturbo
                          • Feb 2006
                          • 10
                          #132
                          Yeah, I have MSII and love it. But I don't know if I'd say its better in ALL aspects. For me it was a good choice because it was easier to tune; I didn't have the time to learn to tune the stock ECM when I already had megasquirt experience.
                          www.khturbo.net
                            #133
                            For a daily driver the stock ECM can't be beat since it has all the stuff in there for different enviro conditions, and little stuff like opening the IAC when the fans turn on/etc. But as far as documentation for the average user, it probably takes a little more digging before you understand it all. It can be made easy though with the right stuff and right documentation. And it's being hacked to support 3 bar, more features, autotune, etc. Just look at code 59..
                            • MidnightriderZ24
                              • Jan 2005
                              • 699
                              #134
                              this car is far from a dd. i like alot of the features that megasquirt can perform, and ease of it. oh well, computer is dead last on my list, so i have time to figure that out.
                              [SIGPIC]
                              • kris gtwhat?
                                kris gtwhat?
                                • Feb 2009
                                • 30
                                #135
                                crazy build midnight. cant wait to see some new youtube video's
