need help with O2 sensor problem
  • AaronGTR
    boost lover
    • Jan 2004
    • 708
    Hey all, wasn't sure where to put this really so trying here. It's kind of a tech question, but more related to performance and tuning 'cause it's the result of modifications I made. I've been having problems with my O2 sensor fouling up for some time now and I'm trying to fix it once and for all. I've tried a few things and have some theories on more things I can try, but if anyone has any better ideas all input is appreciated. First the symptoms...
    The switching of the sensors voltage reading from high to low starts slowing down and decreasing in range (from 500mv in the middle) at around 2000 miles after installing a new sensor. By 4000 miles I'm getting codes in the pcm for O2 sensor insufficient activity and SES light on. By then the car doesn't want to stay running when I start it without me playing with the throttle a little and it hunts around for idle and surges. My wideband O2 typically starts seeing AFR's in the 16:1 range at this point, so it's obvious the stock narrow band is fouled and the pcm isn't reading and adjusting fuel properly in closed loop.
    Basically I think it could be related to two things. Either burning oil, or unburnt fuel going out the exhaust. Reason I think it could be oil is because I've read that boosted cars tend to have more airflow going out the valve cover into the PCV system than average due to the higher combustion pressures and resulting increase in blow by into the crank case. I installed a catch can in the PCV line because of this, but it doesn't appear to be working. The engine is usually about 1/4-1/2 quart low on oil after 4-5k miles, and the catch can hardly has any significant amount of oil in it. I'm still observing oil residue in the outlet hose and the intake manifold as well. I'm thinking the air is moving fast enough through the catch can at high throttle that the oil mist stays suspended in the air and goes right through. Any ideas on how to stop that oil there and let the other blow by gases pass through? I'd like to keep the PCV system intact with suction on it like stock to evacuate the crank case a low throttle since thats the majority of driving I do, rather than just using a valve cover breather. I've been thinking about maybe putting some kind of filter inside the catch can on the outlet side to stop the oil? Or maybe using some type of oil/water separator like for air compressors? Anyone else have experience with similar problems?
    The other possibility of unburnt fuel, I'm addressing right now. I read that higher lift and duration cams actually slow down air velocity in the intake ports when at low rpm and can affect fuel atomization. This problem basically started after my major overhaul when I added the cam, injectors, and deleted the EGR all at the same time... so I figured that might be related. Obviously I don't want to take the cam out and I don't want to re-install the EGR. Scans have shown the injector pulse width doesn't get that high even at WOT redline, so I'm pretty sure they are bigger than I need. They are 42lb disc type injectors that have a jet pattern instead of a mist too... great for high rpm power and a really high injector duty cycle limit, but not so great for fuel atomization at idle. I picked up a set of 36lb GTP injectors that I think should be plenty for how much boost I'm running and hopefully with help with the idle. I'm also using one range colder plugs and a 180 thermostat. The plugs don't look fouled, but with my extra cooling capacity the car will actually run at 180 when the weather is cool. I've heard that engine and coolant temp can affect the combustion efficiency as well, so I'm wondering if that could be part of it? I don't think I really need to run as low as 180, and I have a stock 195 T-stat I can put back in. Basically I'm just trying to make sure I'm getting a complete burn.
    The only other thing I'm changing is my wideband O2. Innovate motorsports contacted me with an offer they were doing for LM-1 owners where they'd let you turn in your used LM-1 and get $100 credit towards a new LM-2. Apparently they are going to give the LM-1's to tech schools and university automotive programs for classroom use. Anyway the LM-2 has a lot more features so I went ahead and got one. It's a full OBD2/CAN scan tool and code reader as well, and has more inputs/outputs than the old LM-1. I can still use one analog output for logging with my powertuner, and it has another one that's setup from the factory to simulate a factory narrow band output. I'm thinking about trying out hooking that up to the signal wire for the factory O2 and seeing if the engine will run better off of that. I'll have to turn off the DTC codes in the PCM for the stock O2 heater, but otherwise if it works I'm hoping it has an easier time maintaining the proper AFR. If it doesn't work I can always put the stock sensor back in. I'm getting tired of buying a new $60+ sensor every 4k though, so hopefully I can solve this once and for all.
    '97 Grand Prix GT 3800 (sold)
    Gotta love boost!
  • torq455
    If I only had money!!!
    • 1615
    sounds like you already know the problem.
    make sure your ignition system is working fine. it's perfectly fine to run the 180 stat. the hotter stat is better for emissions. your plugs most likely look fine since you blow it out from time to time. that extra heat and air clean things out. the 02 is further away from that so it takes longer to clean. also check the AFR at cruise and WOT. make sure it's not too rich. although, if it's rich or burning enough oil to foul the 02 after only 2000 miles, you'd see either black (fuel), or light blue (oil) smoke from the tail pipe. you can also look to see if your rear bumper, by the tail pipe, is clean. that should give you more clues to solve this prob.
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
      • 13530
      Another reason I need to get my wet bench done. I would like to know what the injector spray pattern does at low rpm and high rpm. If the injectors can't be tuned well for idle, then I would say you need different injectors.
      • AaronGTR
        boost lover
        • Jan 2004
        • 708
        Ok now I have another problem, the car won't fire. After I installed the 36lb injectors and put the fuel system back together I turned the ignition on to pressurize the system and check for leaks. No problems and it held steady at 48psi so I put everything back together. Go to start the car tonight, crank it over, fuel pressure drops... wtf?!
        I already checked the fuses and the relay. All good. The pump still gets power and turns on. When I turn the key on it shoots up to 52psi immediately then quickly drops to about 20psi then slowly bleeds down to about 5psi. Anyone ever have that happen before? The only possibility I can think right now is that one or more of the injectors they sent me is bad and stuck open after I tried to fire them. I dunno, but I'm starting to get ticked at this car and I need it running by sunday, so I think I'm going to yank out those injectors for now and put the 42's back in.
        Gotta love boost!
          • 13530
          Only time that happened to me was after I replaced my fuel pump and the damn check valve is shot. Everything drains back to the tank over time and if it sits all night I would have to prime it 3-4 times to get it to fire up immediately.
          If you didn't have that problem before the injectors were installed then having one or more stuck open is a possibility.
          • torq455
            • 1615
            possible the fuel regulator is bad? i thought fuel could seep through and back through the return.
            Andy
            • AaronGTR
              boost lover
              • Jan 2004
              • 708
              I wouldn't think it would be the regulator. It's a fairly low miles casper unit and never had trouble with it. But anyway, I feel like an idiot now. I realized I forgot to turn the kill switch for my MSD ignition back on. Wouldn't be the first time I've done that. I must have been so caught up in setting up the wideband and laptop that I forgot about it. That still doesn't explain the fuel pressure issue though so I'm still a bit worried. Gonna check it out tonight.
              Gotta love boost!
              • AaronGTR
                boost lover
                • Jan 2004
                • 708
                Ok good news. After turning the ignition switch back on and cranking the car over again it fired up on the second try. Fuel pressure is staying up like normal. I had to adjust the fuel pressure regulator a little, but it already seems to be idling better with the new injectors.
                The wide band O2 seems to be making a really big difference in idle stability as well. It took a few tries to get it setup and wired right, but once it was working and the PCM was getting a signal from the wide band's analog output the idle smoothed right out and the AFR stayed steady at 14.7:1 plus or minus about .2. And now I shouldn't have to worry about fouling the stock narrow band O2, and I can calibrate the wide band to keep it accurate.
                Once I finish the permanent install and take some pics and do a little long term testing to make sure it stays working properly, I'll post another thread with the details. So far all I had to do was turn off the code for the stock O2 heater, and no other DTC's have appeared.
                Gotta love boost!
