Not the best, but good enough I guess.
3.1 v6 60... parts selection
I still think 6 carbs, one on top of each runner, would be sweet.Originally posted by SappySE107 View PostI think its a moded equinox upper but I don't know.
A lot of sandrail and MGB swap and other swaps have more demand for carb than most here would even care to imagine. A carb for gen 3 heads would be a major improvement, both in power and efficiency (propery designed). 390 or 450 cfm carb and a distributor.
the fiero engine has iron heads... and the runners are diff... and ya i know i really want 3.5 heads on this
The green one appears to be a Fiero plenum that has been cut, welded shut and a flange welded to the top. If you have the means to weld aluminum, I don't think that would be too hard to fabricate up.
Edit: Hmm... maybe not.
the green one is the ticket.... and hey im here trying to buy one.. and edelbrook does need to but there do not have enough demand for them to make money buy the time they make make the casting
I wanna know how well those work though. The first has some nice bends and the second has no runner at all it looks like. Edelbrock needs to make a carb manifold for the 3400 heads or 3500 heads.
Originally posted by bszopi View PostYou can put a turbo on a stock 3x00 (9.x:1 CR) and get up to 8-10psi without any issues, if you use the aluminum top end. No reason to drop the CR just to add boost.
I agree. Loner's Corsica has 9.1:1 and screams with 12psi
Did a quick search on the site, as I know we've had sand rail people on here before... Here is a nice example of a 3.4 iron head with a turbo : http://60degreev6.com/forum/f96/3-4-...ing-for-t37450
i agree its nice but i limits me to much on my options... tire size plus weight and so forth.. ive seen the conversion done before... my rail has 16 inches of travel.. with the parts i have it'll run.. and run good but im looking to make it run to best i can and really pump some power through this motor its light weight compared to most with alot of options.. if i build it as low compression as i can i could just slap a turbo and go...
