will it survive 28 psi?
  • project89
    • Sep 2008
    • 247
    well i got the motor back to life(it never really died race season just ended)
    shortly after the season ended i modified my setup to swap to twin t3 50 trims.
    but i had some issues with the setup and put it back to a single setup.
    it now consists of a 67mm turbo and 80# injectors with a shitload of methanol injection. starting boost level is 27-28 psi.
    and i updated my ms ecm to a mapdaddy map sensor which is good to 44 psi of boost
    going wot below 70 results in tire smoke and lots of it. though i havent goten on it to much since i got the new turbo in and im running a very safe tune on it for the time being
    10.5 afrs from 15psi up only 16* total ign timing, and a ton of methanol
    38
    hell no
    15.79%
    6
    yes
    23.68%
    9
    whop cares crank the boost and video it
    60.53%
    23
    #1 1989 RS - THE L98 AND LT1/LS1 KILLER
    1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
    #2 95 granprix 3100 all stock for now
    ported heads and cam comming soon, megasquirt ems and turbo down the road
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    You may be the first one doing it so who knows really. What power levels are you at?
    • project89
      • Sep 2008
      • 247
      i really wish i knew,at 28 psi the car pulls so hard compared to when i made that 13.00 run on 9 psi.
      Driving the car now with the big turbo and high boost makes the t3/t4 look like it was a stock motor.
      but of course thats going from the butt dyno
      previously 13.00 @ 34xx pounds would put me around 300 wheel hp i would say that a gain of 150+ hp at the tires is very very possible.
      but i wont really know until 2nd week in march when e-town or atco opens back up
        • 13531
        Dyno it.
        • project89
          • Sep 2008
          • 247
          Dyno it.
          pay for it an i will
            • 13531
            Where are you located.
              • 13531
              Was 60 bucks....I can deal with that. So what day is good for you.
              • project89
                • Sep 2008
                • 247
                http://www.krazyhousecustoms.com/
                heh u serious? shit all the places i could find around me were starting at 150 bucks.
                if the place is close and ur serious ill have the car to the dyno in no time just need to finish up some minor things and get a trailer to tow the car over since we took the insurance off it for the winter
                  In for dyno numbers
                    • 13531
                    They should be the closest place to you with a mustang dyno.
                    • project89
                      • Sep 2008
                      • 247
                      yeah there not that far, my shop is 2 mins off rt1 in milltown so its prolly like a 20 min trip or so
                      whats the diff between a dynojet and mustang dyno?
                        • 13531
                        The mustang dyno should be an eddy current model.
                        • project89
                          • Sep 2008
                          • 247
                          lol u have lost me
                            eddy current dynos are said to be more accurate..
                            • project89
                              • Sep 2008
                              • 247
                              so its a loading dyno then?
                              thats the only im worried about on a dyno is the turbo would lag bad cause the small load
                              if it isnt i could always just lock the converter up in the begining of 3rd gear
