will it survive 28 psi?
  • project89
    • Sep 2008
    • 247
    #121
    im leaving to go pick up the car with my friend in 20 mins,
    i have a few open option sat this time
    60k mile 2.8 stock shortblock is on the engine stand ready to go, so if my block is broke i will do a cam swap into the 2.8 and bolt my topend etc onto it and will be going to dyno the car with that motor in the car
    anyways i will post back up soon as i know what is going on
    #1 1989 RS - THE L98 AND LT1/LS1 KILLER
    1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
    #2 95 granprix 3100 all stock for now
    ported heads and cam comming soon, megasquirt ems and turbo down the road
    • torq455
      If I only had money!!!
      • Dec 2003
      • 1615
      #122
      i don't know very much about turbos...how is there coolant flowing out of the turbo? is there coolant in the oil too? if that's the case, i would be running at all right now.
      Andy
      fastest 1/8: 10.19@ 67.17
      fastest 1/4: 16.16@ 82.70
      • project89
        • Sep 2008
        • 247
        #123
        ok the verdict is cracked block
        BUT its runnable
        i blew the bottom freeze plug out of the rear of the block, and cracked the block inbetween cyls 4-6 and 3-5 right below the deck about 1/2 - 1 inch inch down from the block deck.
        new freeze plug installed, tig welded the block up with nirod and put the trans back in. put a few leak stop tabs in the rad for good measure and i got 0 water leaks.
        tyen i proceded to take the car out on the street and beat the piss out of it at 9 psi.
        holy mother fucking shit the car is unreal
        videos of carnage and street runs and a flyby to be posted soon
        I WILL BE DYNOING THE CAR TOMMOROW MORNING WOOOOOT
        • project89
          • Sep 2008
          • 247
          #124
          the wwater coming out the ex was just condesation and water that ran into the headers when i had the turbo off for a few days
          • nixon5
            • Dec 2007
            • 7
            #125
            lol gotta love a good welder ya can fix anything
            • project89
              • Sep 2008
              • 247
              #126
              watch and weep guys
              introducing the fastest 60* powered camaro ever lmao
              well maybe but well know for sure tom
              9 psi max boost launch at 3 psi smacking the rev limiter at 8grand before shiftiing to second gear
              video 2
              i love the way my car sounds dosent sound like anything else
              • nixon5
                • Dec 2007
                • 7
                #127
                Lmfao holy shit you revved that thing so damn high haha. I guess those welds held
                • project89
                  • Sep 2008
                  • 247
                  #128
                  it wasnt intentional i was having a hard time keeping the car straight i couldnt reach down fast enough to put it in second gear.that and i still havent lowered the rev limiter from 8k down to 7,400 rpms.
                  i may leave the limiter set to 8k for the dyno and then reset it depending on what the power curve look slike
                  • ALLTRBO
                    • Dec 2008
                    • 101
                    #129
                    You've run the car at 28psi but 9psi feels unreal?
                    Are you still going to dyno it at 28psi?
                    '88 Fiero GT - Project MIDTRBO
                    '10 Camaro LT/RS
                    The rest of my cars are for sale (Click here)
                    There's no replacement for turbo placement
                    • project89
                      • Sep 2008
                      • 247
                      #130
                      ive had the car up there on a much larger turbo, it was alot slower down low due to massive lag, but when it hit it hit hard, this 60-1 is sized just about perfect,maybe just a touch on the smallish side for what the car should do.
                      the reason that the car feels unreal now is cause it has so much more comming out of the hole
                      i am not gonan dyno at 28 max boost will prolly be 18 to 21 tops due to the fact the block was cracked and i had to weld it,and i dont know if theres any cracks internally.i need the rotating assembly out of this motor to put in my new block,so im trying not to hurt it
                        still sounds like an old iron head '660.. lol
                        judging by the vids it doesn't seem that fast to me, Get some track times and dyno numbers.. then you can make wild claims like "fastest 60v6 Camaro"
                          Live life 3.7mi at a time
                          • 4555
                          #132
                          I wish sometimes I didn't have to be so secretive...
                          • project89
                            • Sep 2008
                            • 247
                            #133
                            yes i can because no one is faster even with the old turbo so until somone throws down a better time i can throw that around
                            and of course it didnt look that fast the dam thing didnt hook up for a good 70 ft
                            • project89
                              • Sep 2008
                              • 247
                              #134
                              me either when i rip the motor down to change blocks u will see just what im talking about.
                              u guys really have no clue
                                • 4555
                                #135
                                The 3400 turbo Corsica is still spinning at 300'
