Mix'n'Match
  • Khipset
    • Oct 2008
    • 52
    Mix'n'Match
    What I want to do:
    3500 Valves and Springs on a 2003 LA1 heads. I used to use the main 60degreev6 page to look at specs, but I can't seem to access it anymore.
    Anyway, I was wondering, will the 3400 seats, guides, retainers and keepers work with 3500 Valves and Springs?
  • WrathOfSocrus
    • Jan 2008
    • 318
    Yes, the lighter weight 3500 valves are a nice upgrade for 3400 heads and weren't too expensive last time I looked. I believe the springs also have a slightly higher pressure ( around 20 lbs higher I think??? don't recall if that was open or seat pressure that was increased) which should aid in higher RPM stability.
      • 13534
      3500 springs aren't different.
      • Khipset
        • Oct 2008
        • 52
        Excellent. Thank Yall
          they are different than 3400 springs last i knew.. open/closed pressure was higher.
          • MidnightriderZ24
            • Jan 2005
            • 699
            nothin to brag about really. plus the 3500 will most likely have low miles, springs will be nice
            [SIGPIC]
            12.268@117... 11's to come!
            • Khipset
              • Oct 2008
              • 52
              Does anyone have some cheap ideas for Rockers? Will be going on the heads with the configuration as above.
                • 13534
                If you need some 8mm stock rockers, I have a set I can sell for $50 plus shipping.
                • Khipset
                  • Oct 2008
                  • 52
                  Sorry, I should have been more specific. I have a set of stock 8mm's.
                  I am looking for either an easy mod to the stockers to raise the compression ratio slightly.
                  Am also open to other ideas (hopefully on the cheaper side) but I am not fluent enough to figure out a configuration to use.
                    • 13534
                    wow, I should have added that to my april fools listing. Rockers don't increase compression.
                    • Khipset
                      • Oct 2008
                      • 52
                      Ugh, its not been my day. Rocker ratio*
                        • 13534
                        The only way to change the ratio is new rockers.
